Thread: Teg idle problem help please!!!!!!!!!
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Default Teg idle problem help please!!!!!!!!!
    Hi ia, I just recently got a 94 teg and I changed the throttle body on it, its got a real bad idle problem, when warming (I know its sorta normal) it idles at 2000 rpms but after it warms up it jumps from 900 to 2500 rpms constantly! I've changed and cleaned the iacv and tightend the screw inside the fitv and also tightend the idle screw on top of the throttle body all the way down, and checked for vaccum leaks (nothing) no help at all. So what could be the problem?????? Someone please help a bro out!!!! Thanks
    JDM as......
    93 accord cb7
    (traded)
    93 del sol eg1 (traded)
    94 integra dc4 (sold)
    96 db7 ls-t (daily)
    WEST_SIDE
    the TB sscrew u tighten down. back it out some. maybe 1.5 turns. But def one turn other then that, u shold recheck all your Vac line and try a diff IACV.
    Nov 2009
    Bremen
    I've adjusted the tb several times and have put two new iacv on it already?
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    Senior Member StreetHazard's Avatar
    Sep 2008
    my H22 prelude does this almost identical thing, especially sitting in traffic in warm weather and the motor gets very hot, my RPM's jump to about 1500-2000 at idle. And sometimes I get that "lobing" idle. But as soon as I move forward again at a decent speed for a little while, it's goes back to normal.
    and I have no clue what to do about it.
    Nov 2009
    Bremen
    ^^ Its aggrivating as hell
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Same Here
    rockst*rDK EKteknoMunkey's Avatar
    Read this website it tells you how to find out what can be wrong
    http://www.team-integra.net/forum/di...g+Common+Topic
    Nov 2009
    Bremen
    That's where I got all my info and nothing works!!! Lol
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
