Results 1 to 18 of 18
Thread: Readiness for emissions. Help plz!!
    Norcross
    Default Readiness for emissions. Help plz!!
    I have a 96 civic ex. all stock. Car fails emissions because of readiness. Took it to some mechanics and they either say its the oxygen sensor, or something is like resetting the Ecu. I just recently had an alarm put on, but not sure if that makes a difference. Need help asap, reps n thanks for advice
    Always Looking
    Is it throwing a cel?
    Norcross
    no cel is on
    325is NJSC's Avatar
    Dec 2009
    Buford
    what happens is if you reset your ecu it won't be ready to test for emissions for 2 weeks so it has a chance to cycle through to check to see if there are any errors. I think it is two weeks. So because you just had an alarm installed they unplugged the battery for a while and it then reset the ecu.
    that's how I roll
    Norcross
    Quote Originally Posted by NJSC View Post
    its been well over 2 weeks since it was reset, so maybe something is resetting it.. like the alarm? im stumped.
    Always Looking
    ^True and yea it's 2 weeks.
    Norcross
    ooh kk, let me try n find out exactly when it was installed. My mom says it was 2-3 weeks but i'll find out for sure. thanks for replies! keep em coming though
    Always Looking
    if it has been more than 2 wks check your battery connections make sure they're tight, not corroded.
    White 240 Jrh1992's Avatar
    Dec 2009
    If the battery is disconnected, you have to drive ATLEAST 100 miles before all the sensors work properly. The mileage varies for different cars but you have to drive a certain distance. I have cars fail all the time because of MIL readiness.
    They would of had to disconnect the battery to install an alarm, so just drive it around alot and you'll be set!
    P.S. MIL Readiness has NOTHING to do with an oxygen sensor lol!
    PLEASE SHUT THE FUCK UP
    1993 240sx SE- Under Construction
    1998 Ford Exploder- Daily Beater
    2007 Rav-4 V6- Be waiting for you at the next light!
    The 269-hp V6- full of swagger. So equipped, the RAV4 can embarrass quite a few modern sport coupes in terms of acceleration.- Edmunds
    http://www.facebook.com/?ref=logo#!/...?id=1138891012
    Add me^
    Always Looking
    Quote Originally Posted by Jrh1992 View Post
    Oxygen sensor may be the only one showing up in "not ready mode" so it could be a bad sensor.
    Dec 2009
    I am pretty sure that it will say "fail" rather than "not ready" though. It does on my machine, but I have a new machine so maybe it would say differently on an older machine.
    Anyhow, do you have any idea how far you have driven since having it installed? A guestimation?
    Add me^
    Norcross
    its been driven a good amount of miles, im sure its over 100, because my bro uses it for pizza delivery. However, i just changed out the oxyg sensor and i also found out the vtec solenoid was unplugged :\.. Do I need to reset the ecu since i changed out the oxyg sensor? or i should I just go get it tested? thanks again guys
    Dec 2009
    Don't reset anything or you'll just fail again, you only get 1 free retest. Idk if a vtec solenoid effects the emission controls or not.
    If you didn't undo the battery when you replaced the o2 sensor then go get it retested.
    And did it have over 100mi when you had it tested the 1st time?
    Add me^
    Norcross
    kk, yea I'm pretty sure that there was over 100 miles on it, not positive though. Should I drive it around a bit and then get it tested?
    Norcross
    just an update for u guys, the problem ended up being that there was no thermostat.
    YOURMOM tnomud's Avatar
    Coweta
    dude, I have 2 cars "not ready" and have logged over 600 miles on each one...............still not ready
    West palm beach
    Quote Originally Posted by j0nbunklah0m View Post
    wow, never seen that coming...
    NO ADVERTISING
    -IA MANAGEMENT
    lol wtf
