Results 1 to 11 of 11
Thread: Need help with lowering:92 integra
    Chickens Eat Eggs
    south side hoe
    Default Need help with lowering:92 integra
    OK, heres the story i bought the car with eBay coil overs on my stock struts and it had a perfect drop but a shitty ride. about 2months ago i swapped them out for ground control coil overs and kyb gr-2 struts (DAily DRiven)and by that time i would think it would break in...i am having problems lowering the passenger front side.i have both of my front sleeves adjusted all the way down and the passenger front side still sits about a finger and a half higher then the rest and i do not want to raise the other 3 sides too even it out. Does anybody know what could be the problem?????***also i can hear a squeaky like noise from the passenger side when i apply pressure on it(push it up and down)
    1.i was thinking about removing both sleeves and using the springs...bad idea or good?
    2.Swaaping the front struts if possible(maybe that side need some weight to break in)
    3.cutt one of the coils or possibly heat them???
    Thanks for the help IA!
    REpps
    vanilla sky.
    i had the same problem when i had sleeves.im now on fulls and there all set the same.
    no on all 3. check everything make sure u have it all installed correct on that side.
    Chickens Eat Eggs
    south side hoe
    Quote Originally Posted by silverDA View Post
    hrmmm.............
    i tripled checked!
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    i have this problem as of today too. but with me when i make a turn the back shocks or springs make a squeeky noise!
    or atleast in that area!
    L'ville / Gwinnett
    Quote Originally Posted by geezy View Post
    Thats probably your trailing arm bushings
    Chickens Eat Eggs
    south side hoe
    so i was thinking about removing my front sleeves and leaving the springs from the ground controls?????anybodyy done this before with ground controls on a DA????????????????????????????????????
    All Motor BlackDubs's Avatar
    Atlanta,GA
    Does the shock compress down when you push on it? And is your shocks sitting right in your front forks? Im pretty sure you've checked it. Just a thought.
    And I wouldnt ride on just the springs. If you really want to do that, Ill trade you some no name lowering springs I have .
    Chickens Eat Eggs
    south side hoe
    hahaha imma try it too see how it rides!
    Aug 2009
    i knoe why it like that, you are to heavy.. you should sit on the other side,,, nah j/k
    Chickens Eat Eggs
    south side hoe
    Quote Originally Posted by Austin? View Post
    at least i can reach the pedals ohh
