Results 1 to 3 of 3
Thread: MR2 parts and Universal goodies
    Default MR2 parts and Universal goodies
    I ended up calling and end to my turbo and MR2, and I’m going to end up selling my losses and going with a different platform car. So my loss your gain.
    Contact me at [email protected] or text at 229-560-7112
    Engine goodies.
    Brand new toyota 4age standard piston rings. $80 plus shipping
    Machined .10 over 4agze crank. $80 plus shipping
    Brand new SS Line oil relocation kit with extra line for oil cooler same as below without cooler. $130 shipping.
    http://cgi.ebay.com/ebaymotors/15-R...t _3810wt_1253
    Largeport head with cams cleaned and was told it was rebuilt but I do not know if it was. $100 plus shipping
    AISIN oil pump brand new $85 plus shipping
    MR2 Supercharger Intercooler without shroud and has a 9’fan on the bottom $50 plus shipping
    Fidanza adjustable cam gears, Silver and black only ran for 300 miles: $135 Plus shipping.
    Like this but, silver. http://sciontist.com/ProductDetail.aspx?id=100007125
    88-89 4AGZE DLI ignition setup for AFM perfect for a gze swap or someone who wants DLI ignition
    (Custom made harness by phoenix tuning(Dr. Tweak) ECU, Crank Angle sensor, igniter, Coil packs, and wires.) This setup uses a internal voltage regulator so u need a NA alternator or use the JDM 4agze alternator
    $375 plus shipping. The wiring harness alone cost me $350!
    Have ARP rod bolts that were pressed into the rods but never used $40 plus shipping
    2 Pairs of NA valve covers $25 each plus shipping
    JDM valve covers $30 plus shipping
    JDM SC block has been hot tanked and honed $50 plus shipping
    2 NA throttle bodies $25 each plus shipping
    SC throttle body with tps $45 plus shipping
    SC large port intake manifold $15 plus shipping
    4agze knock sensor $25 plus shipping
    Other random engine parts just ask, and I will let you know.
    Fuel stuff
    Na fuel rail with blue top injectors $25 plus shipping
    7mgte 440 fuel injectors freshly rebuilt with paperwork $120 plus shipping
    Bill strong’s fuel tank to 6an fitting $15 plus shipping
    Turbo Goodies
    I have 3 turbos
    Very clean Pro. rebuilt with stronger bearings, No shaft play <1000miles Hybrid 300zx T3 60trim, 60ar. Compressor and a Smaller Mercedes 46ar turbine, Internal Wastegate 300HP+ $255 Plus Shipping
    Two Nissan RB26DETT T28s .42ar Compressor and a .48ar Turbine, Also very clean has minimal shaft play(VERY LITTLE) has some nicks on the turbo from shipping. They do not have wastegates installed, but any T3 turbo wastegate will work, or run an external wastegate. These will spool very fast on a 4age and will support near 280HP. $250each Plus Shipping.
    Rally2 T3 Manifold Very Strong Ceramic coated $275 Plus Shipping
    T3 SS Oil line kit Feed and Drain. $65 plus Shipping.
    T3 Stainless steel 3”Vband Internal wastegate adapter for Vband setups.$55 plus shipping
    3” Vband flanges and clamp $25 Plus Shipping
    Honda 3” Downpipe all it needs is a single cut and reweld for a perfect MR2 T3 down pipe. Exactly like link below $65 plus shipping
    http://cgi.ebay.com/ebaymotors/CIVI...#ht_2587wt_1165
    W2A Intercooler Stuff.
    Brand New Water to air intercooler exact same as the model below: $80 Plus shipping.
    http://cgi.ebay.com/ebaymotors/Turb...es#ht_483wt_957 n
    Very nice Saleen Mustang Heat exchanger like the one below. The all black but does not have fans and it does has NPT fittings. $100 Plus shipping
    http://i161.photobucket.com/albums/...ly/P4170177.jpg
    Brand New Water pump again a very nice unit and well built. $150 Plus shipping.
    http://www.emspowered.com/storefron...products_id=128
    Megasquirt Goodies and Wideband.
    Megasquirt 1 V3.0 Fully asseblled with EDIS and Boost controller, uninstalled tvis switcher setup. Includes EDIS4, Coilpack, VR sensor. Diyautotune 8’ labeled wiring harness, Trigger wheel, Two Temp Sensors, one installed into the Coolant neck and the other in the cold start injector. Also includes random resistors and diodes, and Has a USB to serial cable. $500 plus shipping.
    Brand new silver Technotuning crank pulley with Trigger wheel behind the pulley look at link below. $195 plus shipping
    http://www.enjukuracing.com/techno-...eel-p-8380.html
    Brand new PLX R-500 Wideband/Multipurpose unit very nice unit full info below $300 plus shipping
    http://www.nolimitmotorsport.com/prod/PLX-R500
    Body stuff and Steering
    New Buddy Club replica lip $225 Plus shipping.
    Driver sided scoop painted satin black $100 Plus shipping.
    Brand new AW11 version 2.5 Steering rack *SOLD*
    Transmission Goodies
    AE92 4AGZE Transmission ~38,000 miles No Idea if it has LSD. $250 plus shipping
    AW11 S/C axles $200 Plus Shipping
    ACT Xtreme 200mm pressure plate with low mileage exedy street disc will include alignment tool. $200 plus shipping
    Brand New Custom ACT 200mm Modified street disc that has a SC transmission spline so it fits a 4agze transmission. $125 plus shipping. Will include with pressure plate above if price is right.
    Brand new Chrome moly steel 9lb XTD flywheel same as the link below $155 plus shipping
    http://cgi.ebay.com/ebaymotors/XTD-...#ht_4053wt_1165
    Certified Gearhead Klutch GT's Avatar
    Apr 2010
    any sw20 parts by chance?
    Alpha Kenny Body jesus bonill's Avatar
    ATL, GA
