Results 1 to 15 of 15
Thread: TriniGS Carson Tuned LED 09-10 Lexus GS Mirror Caps Documentary and DIY
    Suwanee, GA
    Default TriniGS Carson Tuned LED 09-10 Lexus GS Mirror Caps Documentary and DIY
    Installed these for TriniGS yesterday. Took some pics along with the install.
    His car sits so nice in my driveway lol. The neighbors were like another GS? Really? lol
    Used this thread for the references but I compiled some steps that were skipped.
    http://www.clublexus.com/forums/gs-t...iy-thread.html
    Start with opening up the door panel, Here's how
    Use a small flathead screwdriver to slowly pry off the cap behind the handle from left to right.
    Once the cover comes off there will be a phillips head screw to take out
    Then there is a phillips head screw behind the hole for the air vent which comes from the dash to the door.
    Then use a small flathead screwdriver to take off the led light housing
    Remove the LED for easy access later
    There is a long phillips head screw behind there
    First roll down your windows it will make thins much easier! Then by pulling towards you pull the panel from right to left starting at the lower right hand corner there should be 9 tabs. Then once the bottom and side are free start at the top corner furthest away from the side mirror and gently pull up. The door panel should separate and pull of. I used a cardboard box to rest it on. Easier to leave it on then to take everything off.
    Then there is a phillips head screw on the side panel that covers the door latch take that off
    Then there is the door trim moulding that is held in with two tabs. One on each side. Simply use a flat head or small needle nose pliers to pry them off.
    On the ABS unit on the door locate the clip that goes to the side mirror. It should be the one on the right. Disconnect it.
    Remove the side mirror bolts. There are three 10mm bolts. Don't worry about the mirror falling off there is a plastic rod that holds it in place.
    Pull from the outside and it should come off nicely
    Make sure the clip comes with it through the hole on the door
    Done
    Do everything again on the passenger side and you are ready for the hard work
    Bring the mirrors to an open space where you can spread out and work
    I used three layers of masking tape along the bottom of the mirror. You will need to do this in order to keep the mirror from scratches and pry marks later.
    From the bottom you will need to pry up using a pry bar or flexhead flat head screwdriver.
    There are two plastic clips holding the mirror onto the plate. Once you get them to separate then it is all easy work
    Take off the two plugs on the mirror with a small flat head screwdriver
    Then the mirror should lift from the housing
    Take off the phillips head screw on the plate
    It should come off with the spring attached
    Pull the plate off carefully, there will be some clicking noise from the ribbed rods that are holding it in place
    Remove the 4 phillips head screws this will release the top part of the housing away from the mirror cap
    What you should see
    Then remove the puddle lamp housing
    Use needle nose pliers to take off the mirror guts from the housing. There should be three
    Pull the insides out
    Comparing the caps. The new one is on top the OEM is on the bottom
    Transferring the tabs
    Now for wiring. Pull the rubber grommet off of the triangle piece that bolts to the car. You will see this clip underneath of it
    Pull towards you and it should pop off
    Run the wire through the pipe.
    Pass the line through the grommet, reassemble, and done!
    Everything back together and wired up
    On the side of the door locate the grommet and hosing from the door to the car. There are two 10mm bolts holding in the door side of the grommet. Take those off and using a flathead screwdriver you can pull the grommet from the car.
    I attached the wires to a long zip tie and ran that through the grommet and through the car. Inside the car you will have to remove the plastic and carpet and feel for the wire coming through.
    Pulling up the driver's side scuff plate to get to the main harness
    As the other thread stated look for the large green and large yellow wires. Those are the ones you tap into. Yellow = driver's side. Green = passenger side.
    All buttoned up
    The Slums of GA
    i just nutted! sick as fuck!
    BMW Bastard MINI's Avatar
    Rome
    Damn, great all around.
    Got a MINI? Don't talk to me.
    FUCK your FADS
    Apr 2003
    nice mod, good documentary.
    Thanks for sharing bro.
    DIY SECTION GOD DAMMIT!!!!!
    Nice tho
    Peek-a-boo mofucka what now?!
    BK ALL DAY
    luv that body style...
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    Carbon does it again
    zoom-zoom-zoom
    Nuh Botha Mi chameleon30038's Avatar
    Gaza Mi Seh
    Quote Originally Posted by DVSRX-7 View Post
    Nice tho
    LMAO.....it was a double feature .... CAR PICS and DIY
    itakepictures
    changaroopouch
    lol nice DIY. but serves no purpose on IA. nobody else owns one LOL.
    This car is AMAZING. It is beautiful in person.! I love it!
    Public Enemy #1
    Dam that is one sexy GS! Those rims go perfect with that car!
    high gravity ftmfw e30pwr's Avatar
    zone1-6
    must has higher res pics! but looks good
    Blog / Don't Click
    Local Photographer
    I <3 Stupid People :boobies:
    ridin threw yo hood
    niiiiiiiiiiice
    :boobies:
    I has stock altima
    Senior Member Boosted FC's Avatar
    Dallas, Ga
    Great writeup & sick car.
    2013 Corsa Blue Optima SX 2.0T
    Jan 2003
    Looking good Trini, and great DIY Tony!!!
