Results 1 to 13 of 13
Thread: 88 civic DOHC ZC help!
    Southside Ridin HATCH
    Default 88 civic DOHC ZC help!
    I just did the dual point to Multi Point Conversion on the Car. Got a OBD0 to Obd1 ECU jumpere harness AND LS ECU.
    It has a OBD1 dizzy that I hard wired in. And the Wires are correct.
    The car NOW turns over and gets FUEL.. BUT does NOT get spark at all..
    I have Double checked the wires 100 times changed the Igniter out, New plugs, Wires, cap, ALL...
    NO SPARK!?!?
    I dont think there is a Fuse for this?
    Please help ASAP, need the car running!
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Hey guys PLEASE HELP!!!!!!!!!!!!
    Work in progressneed slicks!
    Not ur HOMIE! jdmpeez's Avatar
    Jan 2010
    in tha GA!
    goin goin gone!!!
    It's all about JDM.
    CA to GA
    check all your groundings (bust out with your multi-meter) and see if the timing belt hasn't snapped...
    Jan 2010
    in tha GA!
    timing belt new everything new on that hatch its either dizzy or wiring harness we checked all grounds
    goin goin gone!!!
    I'm on a boat!!
    Bump!! Still not running!!
    was the dizzy known working before u installed it. known as in u seen it run not what the guy told u.
    Jan 2010
    in tha GA!
    yes i saw the car run drove it and all that b4 i got the swap out of it. Now its in my car and wont run.. now fuel pump not cutting on and im still not getting spark..
    goin goin gone!!!
    Augusta
    What OBD jumper harness are you using?
    Will it run with a OBD0 ECU?
    Nope doesnt work with Obd0 ecu
    Car was droped off at IMPORTEXPERTS!!!!
    Jan 2010
    in tha GA!
    gona be on the road next week bustin hopefully
    goin goin gone!!!
    Ellenwood, Ga
    question? i was thinking of doing a zc swap in my ej1 coupe. can i use my dizzy from d15b7? will it bolt up to my dx tranny and use same clutch, flywheel, pressure plate? can i use the obd1 harness from my d15b7 i have and run the p06 ecu? if changes need to be made please inform me. I'd like to know whats what before i begin on the swap.
    ^ Why do you want that swap in that car?
    But..
    Your tranny,clutch, flywheel,ect.. Will ALL work with the DOHC ZC.
    Yes you can use the Obd1 harness...
    Use a Obd1 Ecu that you are able to Chip/tune..
