Thread: weber 32/36?
    OSJC RULE!!! 91blackteg's Avatar
    Cumming, GA
    Default weber 32/36?
    so i put a weber 32/36 on my 3tc. The only thing is that it bogs down, when im not giving it enough gas. I was just wondering if there was a way to fix this, like rejetting the carb, or something?
    Garage Zero
    I've got one on a 2tc and have the same problem. I think you need to rejet the carb to fix it.
    Bunny Colvin's Hamsterdam
    Is it a new Weber? Have you adjusted it any? If you haven't already, you may want to go through the setup instructions that come with them.
    When I got mine, the throttle blades were completely closed. The guide said to make sure they were open .050 If I wouldn't have gone through the setup procedure, the engine probably wouldn't have ran.
    Also, check to see that your vacuum is advancing. Where do you have the line hooked up?
    Cumming, GA
    i know that the vacuum is advance is right. How do i adjust the the throttle blades cause it says nothing in the instructions that came with my weber?
    Sell me the car. Call it a day.
    Peek-a-boo mofucka what now?!
    Cumming, GA
    $2500 and its yours!!
    Old skool Toyota
    Dawsonville
    update. Did you get'er running better. I'm getting one for a 20r/22r hybrid im putting together for my RN50
    Quote Originally Posted by 91blackteg View Post
    Are you sure about that? The guide that came with my Weber had all sorts of adjustment procedures in it. Theres a set screw on the base that will adjust the throttle blades if I remember right. I can check my guide this evening. You can probably get the guide as a .pdf from Redline's site or something.
    Heres a lot of Weber info:
    http://www.redlineweber.com/html/Tec...f_contents.htm
