Thread: question, need opinions. (d16z6 content!)
    IA Member d00d's Avatar
    Jul 2009
    macon,ga
    Default question, need opinions. (d16z6 content!)
    Alright, so have a bunch of oil leaks on my d16z6, slowly working through them one by one, friday my spool valve solenoid gasket/filter came in and i replaced it today, however i forgot order the other gasket on the top [replaced 13 in diagram now 15 is leaking a steady stream( had a brain fart and forgot to order) i noticed it after i cleaned all the caked up oil on everything]. now my question is can i just put some black rtv around the outside of the valve where it is leaking, (not on the inside or anywhere near the inside of the solenoid of coarse) for this week untill the new part comes in ? Im just not sure if rtv will hold it untill then, although i know it will come off easy once i get the new gasket in. comments, opinions? i might just drive it this week and check the oil level every day, im just trying to decide if i should go to the store.
    WTB Disco Potato SOHC1's Avatar
    go to the store and buy the gasket...or just wait till u get the one u ordered...
    thats fine. just dont let it be a permanent thing.
    Certified Gearhead Thegrizz's Avatar
    Feb 2010
    Georgia?.
    As long as you dont run that and forget about it.thatll be an ok temporary fix just change it as soon as you can.and scrape it all off then you do
    Jul 2009
    macon,ga
    Quote Originally Posted by SOHC1 View Post
    They dont have the gasket at the "store".
    Titties!!!
    yea honda screwed me on that same gasket too, but that will be changed in a few days, i would do the same because i think those things leak more than we think it will.
    Jul 2009
    macon,ga
    Honda gave me the wrong gasket, i used the correct part # however they gave me the thicker one with the screen on it, causing the corner of the solenoid mouting base to snap off with 9 ft lbs... be careful
