Thread: teggy question
    Certified Gearhead nstygomez's Avatar
    Jul 2009
    marietta
    Default teggy question
    Ok so ever since I got my integra it leaks water through the hatch I think. When it rains non stop all day the part where my spare goes gets water and the passenger side of the floor gets wet also. I have checked the seals on my hatch and I don't see nothin wrong.so idk... has anybody had a similar problem to this? If so let me kno what I can do?
    Chickens Eat Eggs
    south side hoe
    check tail light gaskets for the trunk leak and for the passenger floor leak http://www.g2ic.com/forums/showthread.php?t=192639
    Chickens Eat Eggs
    south side hoe
    should be the same concept for integra's
    college park
    spare tire area is the taillight gaskets
    now with LSD
    ASAP Carclub steelmatt6's Avatar
    Canton/Waleska
    It could be many things. Take your tail lights out anyway, if they have water in them. Run a bead of silicone on the housing, then re-apply the gasket. Then, run a thick bead of silicone (clear) on the outside gasket, and re-install the tail-lights carefully. Allow the silicone to cure.
    Also, check your sunroof drain tubes. make sure they are sealed properly. And if you have an antenna, check the drain hose on that as well.
    Click links for more info:
    this is how you can seal the tail light on the outside. You should still take them out and seal the gasket to the housing, and outside part of the gasket to the car body.
    http://www.team-integra.net/sections...?ArticleID=550
    http://www.team-integra.net/sections...?ArticleID=546
    http://www.team-integra.net/sections...ArticleID=1021
    hope that helps
    Jul 2009
    marietta
    Thanks ppl.. ima try these things... and ima let ya kno if it worked
    Out in the Boonies
    Most likely the seal aroung your taillights or the taillight gaskets. That's what happened with my old Integra.
    Titties!!!
    the hatch seal could be leaking for sure where you are describing. if the passenger floor get wet the sunroof liner may be gone. i know there is an a/c drainage tube on certain cars in the passenger floorboard, and the previous poster is rright about sunroof drainage holes that do get clogged/
    Jul 2009
    marietta
    thanks for the help me, now i gotta get to it havent had time been at work lol
