Results 1 to 40 of 41
Thread: B16A jdm, aftermarket, B16A3 bottom end, del sol interior, tons of parts!!!!
    Oct 2009
    Warner Robins, GA
    Default B16A jdm, aftermarket, B16A3 bottom end, del sol interior, tons of parts!!!!
    I have a few del sol interior I would like to get rid of. I can ship at your expense.
    part around shifter $25
    speaker covers rear $15
    grey part between two speaker covers $10
    back storage compartments $50
    or $60 for all
    * B16A parts are below*
    Last edited by r.etheridge; 05-15-2010 at 08:16 AM. Reason: title change and price change
    Oct 2009
    Warner Robins, GA
    Oct 2009
    Warner Robins, GA
    $70 for everything
    Oct 2009
    Warner Robins, GA
    Default B16A JDM parts
    pics
    Attached Thumbnails Attached Thumbnails -jdm-im-w-tb-jpg   -jdm-cams-jpg   -jdm-crank-jpg
    Oct 2009
    Warner Robins, GA
    more pics
    Attached Thumbnails Attached Thumbnails -power-steering-p-jpg   -pully-st-al-11-jpg
    Oct 2009
    Warner Robins, GA
    alt. is OBD1($40) and pulley set does not come with it
    Oct 2009
    Warner Robins, GA
    Default holley 68mm TB, venom IM, venom adjustable cam gears and more!!!!
    All parts are for a 99-00 civic Si B16A and are brand new. I do have paypal and can ship. I live in Middle GA
    Holley 68mm throttle body part# 112-540 $175
    Venom intake manifold M21-333B $225
    Arias pistons 82mm dome shaped 311855 on crower rods B93744B $400
    Attached Thumbnails Attached Thumbnails -venom-manifold-jpg   -venom-cam-gears-jpg   -aftermarket-pist-1-jpg
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by blown_ss View Post
    i would like more info on those pistons.
    what else you wanna know? they are 82mm dome shaped, they were custom made for myself because when I bought them, they didnt shelf stock 82mm for B16's. They are brand new along with the rings. Built for compression between 11.5 to 1 and 12.5 to 1. made by arias. pm me if you wanna know anything else
    Oct 2009
    Warner Robins, GA
    intakemanifold, fuel rail, TB, and injectors $125
    used clutch $30
    obd 1 alt. in picture above $40
    Oct 2009
    Warner Robins, GA
    Default B16A3 bottom end with jdm internals
    I have a B16A3 bottom end with jdm pistons, rods, and crank. comes will all of that plus oil pump, girdle, oil pan, and picke up, main caps and bolts and whatever else I have layin around that goes to it. The crank may need to be ground( see pics) $160. Will sell with a crank in perfect shape for $240
    Attached Thumbnails Attached Thumbnails -crank-jpg   -jdm-crank-jpg   -b16a3-block-jpg   -crank1-jpg   -jdm-pistons-jpg
    Oct 2009
    Warner Robins, GA
    Default OBD 1 alternator
    ttt
    Oct 2009
    Warner Robins, GA
    Default B16A head crower, manley, internals port and polished and more!
    I have a B16A head with less than 20k that came off of a 99 civic si j-spec. It has been broke down fully and built back up by fox lake out of ohio. Has manley custom valves DIA; length 4.670, tip;.260 crower titanium springs and retainers part# 68185 for the springs and 87093 for the retainers. Built to take stage 3 cams. It also has a port and polish(the entire head) and a 5 angle valve job and the head has been flow checked and it checked out good. Since the head was rebuilt, it has not been used so everything is brand new. I will throw in a complete upper oem honda gasket and seal set brand new as well. Have over $1100 invested on a brand new head. asking $600
    Attached Thumbnails Attached Thumbnails -head2-jpg   -head-jpg   -head1-jpg
    Oct 2009
    Warner Robins, GA
    Oct 2009
    Warner Robins, GA
    Atlanta... everywhere on i85
    you would happen to have the trunk / cargo stuff that go in the trunk would you, like the cardboard that goes over the steelies and the carpet on top of that for a del sol
    your moms house
    are those piston from a ctr ????
    (((((No more 4 door))))))
    Twan Jdm94Coupe's Avatar
    Fairburn
    Arias pistons 82mm dome shaped 311855 on crower rods B93744B $450
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by georgieboi View Post
    no only del sol interior parts i have are the ones you see in the pics
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by Jdm94Coupe View Post
    thanks jdm94
    Oct 2009
    Warner Robins, GA
    bump!!!!
    Oct 2009
    Warner Robins, GA
    Oct 2009
    Warner Robins, GA
    made some changes on prices and added a few things
    Oct 2009
    Warner Robins, GA
    ttt
    Oct 2009
    Warner Robins, GA
    weekend bump
    theMagician JGilbert312's Avatar
    Feb 2010
    Calhoun, GA
    bump for looking.. Wish I had the money for that head lol.. GLWS.
    kick ROcks!!!!!! kholla6's Avatar
    Sep 2008
    dville
    interested in the cams and ecu if still available lmk asap!!!!!
    [IMG]hondaaccord4.jpg[/IMG] T.E.T.E.T.E.
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by kholla6 View Post
    yeas I still have them pm me
    Certified Gearhead 93delsol15's Avatar
    tennessee
    trade ya an ls long block for the piston/ rod combo
    d15b7 fs 300obo has to go soon
    Oct 2009
    Warner Robins, GA
    sorry man no trades
    Aug 2009
    do 100 for the good crankshaft?
    Oct 2009
    Warner Robins, GA
    yeah I can do that. PM me
    Sep 2008
    dville
    Quote Originally Posted by r.etheridge View Post
    sorry man no trades
    you have a pm bro!!!! lmk asap
    Oct 2009
    Warner Robins, GA
    PM replied
    Oct 2009
    Warner Robins, GA
    This is what I have left and with new prices
    cometic head gasket(new) $50
    holley 68mm TB (new) $150
    Unorthadox pulley set (new) $120
    airmass headers comp blu (new) $100
    moroso oil pan w/pick up tube B-series (new) $200
    crower connectiong rods on arias pistons 82mm dome shaped w/ rings (new) $400
    venom intake manifold b-series (new) $200
    head w/ all performance parts installed (new)(read first post in this thread for details) $550
    stock crank $75
    jdm cams and gears $75
    energy suspension motor mount inserts (new) $25
    OBD1 alternator $30
    JDM valve cover (blue and white powder coated) $150
    power steering pump off of civic si 99 $30
    complete jdm IM,TB,fuel rail and injectors $100
    used clutch and pressure plate stock( 75% left on it) $20
    B16A3 block $100
    B16A3 piston and rods $50
    Oct 2009
    Warner Robins, GA
    Certified Gearhead sang's Avatar
    Nov 2009
    stockbridge
    ups for you bro. got n intake yet 4 your d yet?
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by sang View Post
    yeah man my homie that lives in perry gave me his old one the other day but I appericate it.
    Nov 2009
    stockbridge
    no problem man
    Oct 2009
    Warner Robins, GA
    ttt
    Oct 2009
    Warner Robins, GA
    somebody get this head!!!!
