Results 1 to 21 of 21
Thread: trying to lower need help with lca bolt...'00 civic.
    Exclamation trying to lower need help with lca bolt...'00 civic.
    ok so when we were trying to lower my civic its a 2000 civic ex, we torqued off the lca bolt, i've been told it might do that but decided to give it a shot and we torqued the head right off. so now i'm stuck without a lowered car and i have to get a new bolt for it or i have to get a new lca, and i'm worried it might happen on the right side also. can anyone help me out with this anything helps, also i've heard when this happens you have to mechanically have the bolt pushed in with the bushing or something with some kinda tool, i've googled this all over but cant find much help. ANYTHING HELPS!!! thanks alot.
    Alpharetta
    FAILED!!!!
    Quote Originally Posted by chinitoxamor View Post
    FAILED!!!!
    in a way yes, the car still drives fine i mean its still screwed in just cant get it out without tapping it out, but i mean i know i can buy another bolt, but where and what to do once i get it since it has to be professionally installed now lol, i was wondering if there was another way to fix this myself since shops are like 400$ to install haha fuckkkk
    Jan 2010
    Hahaha man i just put my lca on today too. and had the same problem on one side too. haha. man wat i did to the other side was use an impact gun and pb blaster to loosen the nut. as for the torqued one i had to weld on a bigger bolt onto it be able to take it off. thats one way to do it. just make sure u use a 14 and not 9/16 and spray the bolt to loesen it. i have to spare bolts that go in there if u want them.
    Jan 2010
    I also got the stock lca if u want it
    Quote Originally Posted by Eman_jDm View Post
    wow man finally someone feels my pain haha, ill try using the impact gun and pb blaster also but could i get those spare bolts and that lca from you? i could pay ya for shipping or i can come get them that'd be a huge huge help i appreciate it. and you said you welded a bigger bolt on? what i mean by we torqued the head off, is that the whole head just snapped off and its smooth on the lca now lol its gone. i dunno if thats what you were talking about or not just makin sure
    and we sprayed the shit outta the bolt with wd40 before we tried gettin it off but that didn't really help lol obviously
    MI55ILE Mantooth's Avatar
    Dec 2009
    Changes weekly.
    Quote Originally Posted by ryanfincher View Post
    You should have used PB Blast, imo.
    Your sig gave me a seizure.
    - IA Management
    www.facebook.com/wes.monteith
    Jan 2010
    Yea i got 2 of those long bolts left. what side do u want the lca. pb works way better. i dont want to shiP. you'd have to come pik them up im in norcross. what i did was strip the head all the way till it was round. lol
    okay i think all i will need is the two long bolts my lca is not messed up it is only the bolt thats broken, and norcross ga?
    and do you know about the bushing inside the lca? i read somewhere that you have to have it pressed in with the bolt or something with some kinda tool, did you have to do that?
    torch>deep creep>pb>wd40
    Jan 2010
    Na idk about any special tools. yea norcross exit 101 off of 85 pm me around 2 im goin to sleep now.
    Alpharetta
    i guess i'll get around to this when i change over to my blox lca
    Newnan
    drill it out.. thats what i had to do.. it's very hard steel bolt so find a verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrry strong bit.. start small and work your way up then bolt extractors and you should be able to get it out..
    make sure you keep the drill oiled at all times to keep from dulling your bits.
    learn to english
    college park
    Quote Originally Posted by Humphries View Post
    hit it right on the head i had the same issue on my integra i actually ordered all brand new bolts from honda when i replaced mine tho i didnt want to take the chance of this happening again the bolts are like 4 or 6 each just something to think about.
    if you use old bolts then your going to be right back in the same boat when it comes time to install new full coilovers or you want to upgrade your lca so why not have something new in there that wont rust out?
    now with LSD
    Senior Member AMD_Civic's Avatar
    if you go to sears they have a tool set called the screw extractor set its like 20 bucks...you use it to drill the stud then use the other tool that came with the set to drill it out..!! thats what imma bout to do with the broken mount studs on my block..!!
    blank
    nowhere
    same thing happed on my 2000 hatch couple weeks ago i just went ahead and replace the lca and left the damn bolts in there. both sides broke off
    Southside Ridin HATCH
    ^ O shit..
    The Bucky
    Depending on which bolt you brake the head off of these are all good solutions...one of the easiest ways i believe is this....
    all bolt holes/ nuts that these said bolts thread into on hondas,acura basically any car your working on are welded at 3 of the 6 corners...
    this being said take a Die grinder (preferably) or chisel to the weld to remove them....
    after thats done take a punch or fillips screw driver and a hammer to knock out the remaining bolt end (if needed to loosen rust use PB Blaster)....
    replace with a factory bolt and a 14mm nut( you can re-weld the nut if wanted )
    This can be done to the 2 bolts closest to the brake assembly. The bolt on the sub-frame may need to be cut one more time. In order for it to be removed fully. do to its length.
    ok one last thing i;m about to order new bolts but when i get the stocks out will i have to buy new bushings or something i keep hearing that its a bitch to fix the bushings, just wondering if i drill it out it will mess up the bushings, or can i just replace the bolt and go with it? thanks
    Champ
    Feb 2010
    Warner Robins GA
    downs i did the same thing on my car the nut on the back side is tack welded so get a 19mm socket half inch drive socket wrench. and also grab a breaker bar my broke off with so much ease it was a joke then i just got a bolt and nut! PROBLEM SOLVED
Tags for this Thread
