Thread: JBL GTO 1201.1(2)amp
    georgia
    Default JBL GTO 1201.1(2)amp cash or trade
    got 1 for sale great amp plenty of power 100% perfect and more than enough power for a car or suv. the picture is as it is now i can get more of the sides and bottom if you like but like i said its 100% perfect, its an impressive lookin amp and also has the option for neon or led lights if thats your thing.i love the amp but i cant use it with my current sub ....price 150.00 or trade for a 1ohm stable amp since my sub is 1ohm, let me know what you have....
    here are the specs from crutchfield.......
    JBL Grand Touring Series II amplifiers create a sound and sight sensation. The aggressively modern amplifier case features a see-through cover which allows you to install internally-mounted neon tubes for an entrancingly cool backlighting effect.
    The GTO1201.1 II mono amplifier incorporates an efficient power supply that delivers a big sound with low distortion. A variable frequency filter adjusts the amp's output to best fit your system's specific needs. When you're craving more thump, the bass boost circuit kicks things up a notch.
    The convenient top-mounted controls make it easier to set up and tweak your amp, while preamp outputs simplify adding another amp into your system. An optional wired sub level remote is available(you gotta order that)
    •787 watts RMS x 1 at 4 ohms (1,114 watts RMS x 1 at 2 ohms)
    •optional internal neon lighting (accommodates Street Glow AN9 tubes or equivalent, tubes not included)
    •variable low-pass filter (32-320 Hz, 12 dB per octave)
    •variable bass boost (0-12 dB at 50 Hz)
    •MOSFET power supply
    •preamp inputs and outputs
    •CEA-2006 compliant
    •fuse rating: 40A x 3
    •1/0-gauge power and ground leads recommended — wiring and hardware not included with amplifier
    •18-11/16"W x 2-3/8"H x 12-5/16"D
    Attached Thumbnails Attached Thumbnails -gto-amp-jpg
    yes i am....
    georgia
    this amp is real nice someone pick it up!!
    yes i am....
    JDM-EJ1 shadowx3's Avatar
    G-County
    georgia
    obo people!!
    yes i am....
    Got Vtec?? BigDsGTP's Avatar
    Jan 2010
    Monroe, GA
    Do yo have manual or original packaging?
    georgia
    Quote Originally Posted by BigDsGTP View Post
    i dont have the packaging but i can print out the manual. not much to the manual its pretty simple to set up.
    yes i am....
    georgia
    SOLD!
    yes i am....
