Thread: Trying to wire up headunit.will only eject...
    Default Trying to wire up headunit.will only eject...
    So wired everything accordingly..to the instructions and all the headunit will do is eject...won't come on and play music...hmm any ideas lmk asap...thanks
    cars
    Throw some specifics in there too. What car? What headunit?
    Projects
    Quote Originally Posted by jr4mny View Post
    I had the same issue before and the orange/Yellow wire was either connected/touching to the red somehow or on the wrong wires. Take the radio out and hook up to a 12v battery make sure it works that way to determine if a Unit issue.
    Sugar Hill, GA
    if it will only eject , sounds like you arent getting 12V Accessory
    It's in my civic 98.. Uhhmi tried two different headunits one out f my buddies civic with harness an all and it just did the same thing...
    Now the fuse up front in the bay for the radio was blown so I took out the 7.5 and put in a 10..would that create a issue since it isn't a 7.5
    cars
    Projects
    Some cars wont let you use bigger fuses others will idk about the civics
    Just changed the 10a fuse back to a new 7.5 and the problem still continues... Any other ideas guys
    cars
    georgia
    i have had aftermarket harnesses that were pinned wrong before. that may be the issue. if not get a probe to test for current. probe the red wire or ignition acc wire with the key turned on to see if you get power . and make sure the harness you used is pinned correctly.
    yes i am....
    Lemme check ofhis other fuse under the dash
    cars
    changing fuse sizes doesnt do anything..check to make sure you have 12 volts constantly on the yellow wire,and make sure you have 12 volts when the ignition is on on the red wire
    ______________
    The fuse under your hood is for your memory (yellow) wire and like someone else said it sounds like you do not have ignition (red) the fuse for that one is under your dash on the driver side try checking that out
    Late reply but I did fix the issue, both radio fuses were fried, replaced them and fixed the problem :-)
    Thanks for your input guys..always appreciated
    cars
