Results 1 to 13 of 13
Thread: good set up for f22 non vtec?
    Certified Gearhead cprtyler's Avatar
    cedar town
    Default good set up for f22 non vtec?
    f23 vtec head (is this a swap like lsv if not whats necessary)
    f22 block
    h23 pistons
    f23 crank and rods
    i/h/e
    im steping out alil i have these parts just laying around
    just wanted to c if it was worth the time?
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Del sol w/h22 all motor
    Del sol w/ls swap sold
    Dc2 Itr ft w/B20v dd
    im a organ donor :) 00 blk G20t's Avatar
    Nov 2009
    canton GA
    maybe if you turbo it. im not 100% sure but i believe DSM turbo manifolds will bolt up to f series get a big 16G and use the dsm injectors.....could be a cheap alternative for you.i mean i dont see that motor combo putting much more than 170 down if your lucky to get that much. i still think that all motor it will still be weak-sauce.
    Best G20 SR2009 convention
    in attendance Nissan national convention 2010(Omaha, Nebraska)
    top 20 hotlanta autofest 09
    known as Charles
    There are a few problems with this combo.
    1 - H23 pistons are 87mm and F22 block is 85mm.
    2 - With the combo you have the pistons will stick out the top of the cylinder .022" and the stock headgasket is only .026". That is a little too close.
    It looks like you are using F23 head, F23 crank and rods then why not just use an entire F23 motor. Also, the Vtec on the F23 is a little different then other single cams.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    I would use the f22 head rather than the f23. There isn't much aftermarket support for that head.
    At Home
    Boost would just be easier. Go with a F23 motor of F22... No need to go Franky.
    Both motors can hold some solid numbers with the right turbo and tune.
    cedar town
    Quote Originally Posted by Main Stream View Post
    thanks, i havent built a f/h b4 and the only reason i was thinking bout it is because i just have these parts laying aroundin in great conditiong. the reason i dont use the whole f23 is because i only have these parts. next question can i just slap the f22 vtec head on it, because my non vtec head is bad, if so is this like lsv or is this as simiple as putting a head on? can the f23 crank and rods and pistions work? is that going to be too high comp for turbo later?
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    I say get yourself some flywheel bolts, make a custom adaptor with a chain attatched to it, bolt said adaptor to the crankshaft.......and use it as a boat anchor.
    My line of work
    www.internationaljets.com
    cedar town
    lol ill just stick with b series may have a few thigs for sale later lol
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    KNXWLEDGE EssexCounty's Avatar
    South Side
    Have you considered the h22 head..?
    Senior Member G.C's Avatar
    Forgot
    Quote Originally Posted by PredatorRace View Post
    SHH
    :idb:
    F23>all / thread
    cedar town
    yeah but heard it wasnt worth it?
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    F22>all / thread
    Fixed.
    After my car is put back together, I still want to run you.
    OP, I made 300+ with a BONE STOCK F22A1 turbo'd at 13psi. ARP the heck out of it, maybe some bisi rods and pistons for good measure and ride out. The only reason my motor blew up was because I was messing around with my EBC and ran 18psi on accident.
    If you need a non V F head, I have an F22B2 head I'll sell you for the low.
    F series arn't great for all motor, unless you do an extreme build (Bisimoto, F22A1. 9.6@150 1/4). the A1 is also great for boost. It's one of, if not the best, flowing heads that Honda makes and it's stock compression is 8.8:1, so you can run 12psi daily, beat the heck out of it, and still have a reliable car. Of course, the right tune and fuel supply are needed. I was using an MSD Boost timing master and Aquamist MF-2 Injector controller along with an AEM Uego Wideband to keep everything in check when my car went down. Now I'll be using Greddy Emanage Ultimate and the AEM Uego.
    If you need any advice, i'll do my best to help out.
