Thread: 93 civic VX - motor bogs some at acceleration
    Senior Member Schugg's Avatar
    Default 93 civic VX - motor bogs some at acceleration
    At times when im driving and i slow down for a second, when i go back to accelerate its like the motor bogs down and wont get any response from the gas pedal. car has high miles, and i just did the water belt and timing belt a month or 2 back (pretty sure this was an issue before that tho), i have not checked the timing with a timing light or messed with the distributor since doing that tho. i have no CEL lights, not sure the last time the spark plugs or wires were changed, o2 sensor on header is pretty new, not sure about if or when the fuel pump or filter were ever replaced
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    barrow county
    Quote Originally Posted by Schugg View Post
    car has high miles, and i just did the water belt and timing belt a month or 2 back (pretty sure this was an issue before that tho), not sure the last time the spark plugs or wires were changed, not sure about if or when the fuel pump or filter were ever replaced
    you answer your question with your question.
    it has high miles so you need a tune up.
    check timing belt to make sure its right
    Columbus
    when you go to accelerate and it bogs, does it jerk quickly and suddenly the power returns? kind of like a skip or hesitation.
    or maybe you're low on gas. lol. but yeah, most likely spark plugs, oil change, and wires.
    barrow county
    Quote Originally Posted by 99jdmLs View Post
    if its like that then vac leak prob
    no when it does it, and i go to accelerate it just starts out as being bogged down or whatever, then i either just ride it out and it will go fine after a few seconds, or i take my foot off and back on and that sometimes fixes it. but im prolly going to change a bunch of stuff soon then ill see if it still does it
    - 2008 Acura TL-S
    Новак 5speed's Avatar
    Conyers, GA
    All of that and maybe transmission fluid. Have you checked that? I sure hope you keep up with that.
    Amen.
    Out in the Boonies
    Could be the problems you stated:
    Bad wires/plugs
    Bad coil
    Clogged fuel pump/filter
    Could also be due to bad injectors
    got the plugs, plug wires, distro cap, ignition rotor all changed out sea foamed the gas and intake manifold and finally checked the timing........ after i let it idle for about 15 mins, i set the idle to the recommended 600, and my timing is lining up with the middle mark of the 3 at about 6 degrees!.....10 off from the 16 (+/- 2). but the distro was already adjusted all the way advanced/counter clockwise. will sliding the timing belt off the cam and turning it to the left or right 1 tooth fix this? if so, to retard it from that side which way would i need to adjust the teeth?
    - 2008 Acura TL-S
