Thread: 98 Civic Cluster speedo problem
    Out in the Boonies
    Default 98 Civic Cluster speedo problem
    The break down:
    Car:1998 Civic Ex 5sp
    Problem: Cluster - When driving, the speedo will work fine for about 3-4 minutes. Then out of nowhere, or sometimes when I hit a bump, it will start bouncing up and down then sit at 20mph. Every once in a while it will start to work again like normal. Sometimes when I sit at idle it'll do the same thing. Starts bouncing and then sits at 20mph. Then when I start driving it, it'll work .... sometimes.
    Could it be the cluster itself or could it be the speed sensor? Or what other issues could it be?
    check that speed sensor plugs and the pull it apart make sure everything is right on the inside.
    when we took off my bro-n-law dizzy, the plugs wasn't on good. When we drove it, the rpm will jump up and down, and the speedometer will go up and down to. and for an odd reason, it died lol. We ended up just touching the plugs and messed around with it, and it cranked back up and everything was fine.
    Augusta
    just pull the vss plug clean with brake clean or carb cleaner, put some electrical grease on it and plug it back in. Should fix it, if not you may need to swap VSS's.
    Jan 2010
    My car did the same thing when it rained hard. not really sure y. I took it to get the cel fixed to pass emission and it stoped and hasnt done it since then. its not your cluster though probably just some sensor.
    AccuracyPerformanceAutomotive
    x2 that vss plug is bad about getting hot and melting the terminals.
    500whp of spinnin fury!!!
    When you clean the VSS make sure to add some dielectric grease tot he connector before plugging it back in it will help to keep it dry.
    NO ADVERTISING
