Results 1 to 10 of 10
Thread: HUGE Garage Sale
    -zen motors-
    at the shop
    Default HUGE Garage Sale
    HUGE GARAGE SALE!!!!!! All prices are somewhat negotiable. All parts are used unless stated otherwise.
    Q45 Throttle body, polished - $125
    Factory IS300 amplifiers - $50/each
    Siemens 870cc Injectors. Purchased from SRT. They have 0 miles on them. Ended up swapping them out with 1260cc injectors. There are only 5 pictured, but I have all 6. the last one was replaced due to a factory defect, however, for some odd reason, they don’t make black ones anymore, so the 6th injector is silver. - $400
    HKS replica fuel rail. Does not come with any hardware which will be reflected by the price. - $40
    Modified oem headlight with 4” to 3” scoop. - $225
    52mm Gauge cup - $20
    Polished Upper GTE Intake manifold - $200
    Tein EDFC - $175
    Token Solutions O2 Sim/delete. Brand New. For 01-03 $130
    5LED Wedge Bulbs. $8/pair
    DEFI Heads up Display. Shows mph and rpm. - $100
    Grounding Kit. 8 wires. - $50
    ECU Cover painted GGP. As you can see in the pic, we cut a section out for a wiring harness. - $30
    HKS Sponge Filter. Will only fit HKS 4” filters. Nothing wrong with it, just swapped in a purple one. $15
    SC300 Cam Cover - $40
    OEM Injectors - $10/each or $50 for a set of 6
    OEM Fuse box cover - $30
    Lower OEM Cam cover - $20
    OEM VVTI Cam Cover - $40
    OEM Clutch, Pressure Plate, Flywheel, W55 Transmission, Shifter, Slave Cylinder, Driveshaft. - $1000
    OEM Alternator - $75
    Turbo Blanket - $30
    OEM Slave Cylinder - $50
    OEM Fuel Rails – 1 has been modified for a return feed - $30 and $40 (modified one)
    Turbo Heat Shield - $75
    i like cheese atl gts-t's Avatar
    in the bushes
    hey its stephen with the black sc300..hold the tein parts..ill get that this weekend..k
    warm snugly hugs.....:me:"hey thanks man..car is pretty cool." :mike:"not a problem..you want a hug to seal the sale?" :me:"i guess so..sure." :mike:"mmmmm..you smell nice." :me:"thanks..but can you take you hand off my ass?" :mike:"oh..yeah sure..in just a sec....shhhh..dont cry its ok..just go with it." :me:"im scared." :mike:"i know but it just feels right."
    ^^ done deal.
    Zen Motors LLC
    Local Phone:770.904.2868
    E-Mail: [email protected]
    Website:www.ZenMotorsLLC.com
    Bad Luck kID FAM0U5's Avatar
    Dec 2008
    still have the sc300 cam cover?
    -zen motors-
    at the shop
    yup
    w00t Black Mamba's Avatar
    Nowhere Near You
    U guys have any springs/shock combo deals for Is300s?
    NWS FTW
    IA Member Gwb's Avatar
    Snellville
    bump for a good guy. you wouldnt have a aftermarket exhaust lying around would you?
    -zen motors-
    at the shop
    no used spring/shock combos, but im sure i could work you out a great deal on new parts.
    and no used exhausts at the moment either. sorry.
    Bump! I want that 5-speed!
    Sep 2008
    oxford
    that hks rep. fuel real can it fit a sc300
    dadriver
