Thread: Subwoofer problem plz help!
    Default Subwoofer problem plz help!
    My sub stopped workin n now it only works when I push down on it. Can someone please tell what's wrong wit my sub?!
    no accord
    alpharetta
    pull it out of the box that its in check the wiring. look at the tinsel leads connecting to the cone, depending on woofer. over time a tinsel lead may break off and causes the woofer to stop working but this is very rare. check it anyways. woofer could possibly be blown. take a meter to it and check the ohm reading on it. if its a dual coil woofer check each side and see if the ohms are what they are suppose to be. if you need help i will guide you through it.
    RESIZE PIC PLEASE
    Sugar Hill, GA
    If it works when you push in on it, Its the Tinsle Leads Broken or the Voice Coil(s) has come separated.
    if that is the problem what can i do?
    Quote Originally Posted by audiowiz View Post
    correct
    Quote Originally Posted by unknown2k5 View Post
    replace it
    Sugar Hill, GA
    replace it[/quote]
    yup, or, depending on brand, get it rebuilt. Most decent companies can rebuild it for you for less than the cost of a new one. Or just buy a new sub.
