Results 1 to 14 of 14
Thread: help! motor noob
    Thats right.. A-ran's Avatar
    Default help! motor noob
    Type R pistons in a gsr, good or bad? Also what kind of cams should i get? keep in mind this is for my dd...
    Feb 2010
    G'nett
    What is your WHP goal?
    around 200?
    pistons good, gonna need more than itr pistons and some cams to make 200 wheel. Mainly getting rid of the gsr manifold
    My line of work
    www.internationaljets.com
    Feb 2010
    G'nett
    Get skunk2 cams, vteckidd header, intake, 2.5 exhaust and a good tune and you should get there.
    IA Member 2.0lef_itbs's Avatar
    mission bc
    CTR pistons would be better
    revolution big mac's Avatar
    ctr pistons in a gsr would be hella high ass compression i would not do it for a dd. get a skunk2 intake mani also ditch that stock gsr
    thanks everyone!
    I have already ordered the type R pistons and i also have a skunk2 intake mani on the way. my biggest thing was cams, what cams would go good with the type R pistons? i like skunk2 cams but idk if the money is there for them...
    dose anyone have anything good to say about the blox cams? i was thinking about getting the blox type b cams. i want something that im gonna feel... i dont want some prissy boy cams but i do have to keep in mind that i have to drive this everyday.
    thoughts?
    Blox B's would be good. I still wouldn't bet the farm on making 200 wheel though. Gonna need a way to tune it. Especially with the single runner manifold being on there, and with bigger cams and the stock low vtec engagement point your mid range will be aweful. Like way slower than it is now. So tuning will make it shine. Even a few "go fast" parts and tuning will make your car much funner even if you don't meet your goals.
    My line of work
    Senior Member 9ussy's Avatar
    tuning is key. Get gsr ecu chipped or p28 chipped or hondata s200.
    But about the cams a buddy of mine had the Blox B cams vtec hit hard but your going to need the valve-train upgrade..
    I had the skunk2 pro1 just as good as the Blox B.
    It's really up to you.
    Out in the Boonies
    Quote Originally Posted by 9ussy View Post
    Pro 1's are better than Blox B's. Are you sure you didn't have the stage 1's?
    I had the Blox B's and they were good cams. With the ITR pistons, a good header (IMO VtecKidd's RMF replica's ), 2.5" exhaust, skunk2 IM, Blox B's, adj. cam gears, and a good tune you can probably net around 175-185whp.
    200whp is doable on a stock port head, but not as easy as it seems. A good port job and valve job can get it there.
    okay cool. well i think i might try the blox type b cams. i live in the columbus ga area and we dont have anywhere other then maybe one place that might tune cars, i need to check into that.
    im taking the head and the block to be done i want everything to be right and hold up for a long time... i plan on getting my head ported as well as gettting a valve-train upgrade to go with the cams. anyone got a chipped ecu?
    the 200 would be pertty nice if i could get up there and i plan on being right around 200 but i really just want alittle more power and want it to last!
    Hwy 315
    Quote Originally Posted by A-ran View Post
    thoughts?
    Here we're running into the issue of what you're willing to tolerate as far as idling issues go. Instead of BLOX type Bs, why not save up a couple more dollars and pick up a set of used Rocket M24x cams that will actually make power?
    -jonathan
    [/URL]
    Jesus Christ is my Savior
