Thread: First SWAP
    Krazy Tiny Tunerz
    Nov 2009
    Rome
    Question First SWAP
    ok im going to do my first engine swap from an accord h22 to a ef h22
    i have been hearing that it is difficult to put a H22 in an ef
    because theres not a lot of room n you have to cut some parts out with
    ef bay now
    Would i have to? or can i just simply swap it with no problem?
    Heres a thought, SEARCH.
    Honda-Tech.com has all your answers
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    wait, you're going to put an Accord H22 in an EF with an H22 and are worried there won't be room for an H22?
    You know you're supposed to take the original engine out, right?
    Swapping may not be for you, my friend.
    Correct Fitment Crew CEO
    Because Only Turds Should be Dumped and Flushed.
    2012 Hyundai Veloster / 1960 Fiat 600D
    college park
    pm sir christopher he knows all you need to do he just did this swap 2 months ago i will tell you now this is not a cheap swap
    now with LSD
    I Am, A Stunt Man
    Quote Originally Posted by JDMJAYDC2 View Post
    oh herrrrooooo
    i will tell you now, it will cost you around 5k-7k if done right!!
    this company, WILL be your bestfriend
    http://www.explicitspeedperformance.net/
    but the only down fall for them is, the h22 will sit low and you cant lower the car to much,
    if your wanting to lower the car a lot, use, hasport, which will cause you to have to notch the hood. and not worry about ground clearance.
    and im telling you now, if you have no patience. you will not get this done.
    if you have anymore questions, you may text me. just shoot me a pm and ill give it to you!
    and be SURE, that you pay for good suspension and nothing cheap or it will affect you dramatically.
    and if your doing the swap, get the whole da front and rear brake conversion, and upgrade them to the big brake kit!!
    BMW Bastard MINI's Avatar
    Rome
    I thought everything dealing with Honda was common knowledge? lolol
    Got a MINI? Don't talk to me.
    FUCK your FADS
    Opelika, AL
    Quote Originally Posted by MINI View Post
    bahahaha!! I was thinking the same thing...weird
