Results 1 to 4 of 4
Thread: tips on differential bearing?
    Default tips on differential bearing?
    ok, so the swap i bought the trans case was busted up pretty bad, i bought a new case with plans on salvaging what i can out of the old, and replace what i have to.
    where my problem is pulling the outer case off the bell housing, i have the ring off the countershaft, and started prying on the case, well the diff bearing is seized in the outer case, they diff bearing in a bell housing is coming out with ease, but sinces its pulling the diff up with it, its not going anywhere
    BTW the trans is a k20a3 5spd trans,
    1994 Honda Civic SI - KPOWA
    HybridRacing/ALLINFAB/KARCEPTS/K-Tuned/Bride/TopOneAERO
    Augusta
    if you can get it to come up just a bit you can use a large socket 19-21 prob and tap the diff down where the axle goes.
    Not sure about the K series ones, but eh D and B's have detent balls you have to remove or the gears all try to come up with the case.
    ^^^not to mention the bolt holding the reverse shaft in place in B's
    My line of work
    www.internationaljets.com
    Quote Originally Posted by solblu View Post
    Do that, if it doesnt work then you may need a press. Make sure you remove all the balls and springs first.
