Results 1 to 15 of 15
Thread: problems help!!!
    roberta
    Default problems help!!!
    ok so i got up and i started my car horrible idle and lots of white smoke...i pop the hood to see that gas is all on my turbo and in it.so i pull the plug from the prob cylinder and its soaked in gas,a proceed to check to make sure im gettin fire from the dizzy to the wire and its fine...i bought new plugs and the problem still exists.i ran compression check cause i though white smoke and its 180 perfect.i talked to one of my buddys who is very noligable in hondas and he said that the ecu might be bad cause the ground for that injector is gone leaving the injector open causeing it to flood the cylinder.plz help peps
    car:94 civic hatch
    motor:b18b1 turbo
    ecu:ls with a chrome basemap.
    rc 440 injectors
    Killing it Since1982 bloodline's Avatar
    new york city
    riding low is like a religion
    roberta
    Quote Originally Posted by bloodline View Post
    ^thats what the hell i said.....
    Southside
    Barefoot help this man lol
    roberta
    thats what i was going to say tony....
    Oct 2008
    it is probably a bad ground at the injector (unlikely the ecu) check physical condition of injector wires where you can....if you cant find anything wrong then take the ground from cylinder 1 and 4 and tied them together, likewise with 2 and 3..........not really a handbook fix but will do the trick
    The crack
    Injector stuck open
    AccuracyPerformanceAutomotive
    Swap the injector with another cylinder and see if the problem moves.
    500whp of spinnin fury!!!
    www.jjspec.com Macon, Ga
    Quote Originally Posted by k3tsurui View Post
    The ecu grounds each injector to make it open so that would probably not be a good idea. If it is one cyl with the issue do what QWK D16 said and swap the injector to see if the prob moves with it. It could be a bad injector mechanically stuck open. Just be careful, you dont want to hydrolock your engine if it is straight dumping fuel continuously.
    Quote Originally Posted by Okie_doke. View Post
    Injector stuck open
    Quote Originally Posted by QWK D16 View Post
    Quote Originally Posted by jjmastertech View Post
    Oct 2008
    cyl 1 and 4 are 180 out of phase from 2 and 3....if wiring is your issue then tying the grounds together will work just fine....it will not fix your issue but at least help you narrow down the cause of the problem...if anything your car will probably run stronger by like 2 hp lol
    Out in the Boonies
    roberta
    ok so i swapped the injectors 3 and 4 and now the problem moved so im guessing the injector....so now i guess i need to try a new injector to see if the problem still exists..
    Warner robins ,Ga
    interesting ive never seen that before.
    ^^this guy loves you jdm-civic's Avatar
    the sky
    stuck injector. i had the same problem with my sentra. swapped it out a no more problems........ tip: you might wanna keep a fire extinguisher or something near since your dealing with heat, raw fuel and spark.......... the last thing you need is a roasted car.
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
