Results 1 to 40 of 40
Thread: why do headers turn blueish, goldish color?
    ^^this guy loves you jdm-civic's Avatar
    the sky
    Default why do headers turn blueish, goldish color?
    ive noticed on every set of headers ive installed after a day of driving they turn like a blue-purple color.....why does this happen? just curious?
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Jan 2010
    Im gonna go with heat...
    revolution big mac's Avatar
    heat man, thats what makes it change... stop making stupid threads and google something once ina while
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    bad rings
    Southside Ridin HATCH
    HEAT..
    yea your threads SUCK!
    Also cheap header.. LOL
    the sky
    they will get better one day........but until then,
    i really get tired of seeing your stupid ass threads. why do you make them? you're making a lot of noobs look good. so with that said your probe is not jdm, yes you should trade it for a gsr, kill yourself with those spark plug adaptors, and its common fucking sense of why headers turn that blue color.
    emartu
    Lawrenceville, GA
    i believe its the combo of heat+oils...nothing to worry about in my mind.
    *NY Driver* CeOTiO8's Avatar
    In your girl
    I LOVE'S me some Ebay header
    PROUD SUPPORTER OF BAM-TECH WTF?
    In your girl
    I wonder why jdm-civic is not in the red yet...
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    Quote Originally Posted by CeOTiO8 View Post
    I'm trying damnit!
    bump wish had the cash for a tranny
    Epic Foxbody Thread Crew Member #01
    Heat, after years of it, the chrome plating will start to chip off and it will look like a crazy surface rusted header. The Rx-7s generate a LOOOOOOT of heat so the headers turn blue within the first 2 or 3 days, and at flaking by the first year, after2 or 3 years, it looks like this (the orange/brown pipe in the mid-bottom):
    It's harmless for you lower exhaust gas temperature piston guys, and it's not even really a problem for us rotary guys unless the header is 15 or 20 years old.
    nice meeting you bodhi's Avatar
    Quote Originally Posted by jdm-civic View Post
    because you touch yourself at night.
    top 5
    "get with the Gs, or get on yo knees"
    LAWRENCEVILLE
    Quote Originally Posted by blown_ss View Post
    X2 This kid is a waste of bandwith!
    Hella stock member!
    if you wipe them down before your first startup usually you can keep them all one nice color.
    Simple, its during the tempering process. The colors depends on the metal content and the temperature. Purple to blue on stainless steel is typically 450-600°. Higher chromium content or a chromium coating will make most metals more resistant to tempering...
    Quote Originally Posted by browningboy7 View Post
    I'm trying damnit!
    I'm trying damnit!
    I just helped you out a little.
    Out in the Boonies
    LMFAO at this thread.
    the sky
    lol! you guys bring the lulz!!
    Certified Gearhead Nguyen128's Avatar
    It's more like at you, not with you.
    the sky
    with, at, samething
    ALL CAPS JITB's Avatar
    i appreciate people for asking questions instead of thinking they know everything.. if you dont know you dont know! you got to ask to learn... ther is alot of people on IA that talk alot and dont know anything..
    i dont know myself so i googled it..
    seems like speedminded was right!
    Gold and blue pipes result because the exhaust is running too hot. There are three reasons for this. The first, most common reason, is that the bike is running lean. A lean mixture causes exhaust temperature to rise very sharply. A slightly rich mix WILL NOT CAUSE BLUED OR YELLOWED PIPES.
    However, a *VERY* rich mix can result in an extreme case of bluing. This happens when the mix is not completely burned in the combustion chamber, (either due to a too rich mix, malfunctioning coil, burned valve, improper timing, or whatnot) and rather ignites INSIDE THE EXHAUST. This can result in an exhaust pipe that GLOWS RED while the bike is running. Only in this extreme case can a too-rich mixture cause bluing.
    The common myth that blue is lean and gold is rich (or the reverse) is just that. A myth.
    Third, long periods of idle can cause pipes to blue because there isn't any airflow to blow off the heat. (Some people let their bikes idle WAY too long upon start up before they take off)
    Some pipes can not be restored to the original chrome finish. Others can come back close with using Blue Away.
    If the pipe(s) doesn't come back to looking like you want, chances are there is an exhaust cover (chrome plated) you could put on the pipes so the blue doesn't show
    Apr 2009
    warner robins
    queer f this thread
    your mom loves me
    in a paint booth
    they turn blue because of the oil on them if you put new headers on and do not clean them with alcohol and water before first start up they will turn colors but i have a set of headers that i put on over a year ago and they are still chrome i do this all the time on the motorcycles i put new exhuast on
    Out in the Boonies
    Quote Originally Posted by JITB View Post
    True, but the thing is is that it's faster to google/search it than to post it on the forums and wait for an answer. A right answer that is.
    Oct 2008
    most if not all headers go through some type of machining process and in order to machine metal...oil is use in the cutting and drilling stages...some of that oil transfer onto the product....most manufacturers leave the oil on there on purpose to help prevent rusting...you can do like whathisface said and wipe it off but it will burn off eventually anyways...just like the oil on new brake rotors....ever install new one and notice them smoking?
    i spray oil on my rotors and let them smoke regularly ....cuz i am badass
    The same reason your face turns blue when you suck my dick.
    the sky
    ^^ well at least we know who the IA homos are.....
    sleeve me please?
    monroe
    well hmm that could be a lot of things like burnt rings over heating your vtec is cut off and its not cooling correctly or you ask stupid questions which mean dont touch your car ever pay someone LMAO
    sleeve me please?
    monroe
    you have to classify homo like sexual, sapien, atc.... but theres only one classification for stupid theres jsut a lot of words so G/J
    Jun 2009
    Phenix City, Alabama
    this is truely the stupidest question i have ever seen asked on here. lol
    vanilla sky.
    i just read this thread,awesome.
    high gravity ftmfw e30pwr's Avatar
    zone1-6
    lawls @ the thread. it can also be due to the heat affected zone of the weld depending on the material of the pipe that is welding together.
    Blog / Don't Click
    Local Photographer
    I <3 Stupid People :boobies:
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Holy hell.
    Nov 2009
    Carrollton, GA
    Its caused by the vtack
    had to write something
    Chattanooga,TN
    Quote Originally Posted by ej1boy95 View Post
    You knew exactly why before you came in this thread didnt you? I certainly hope so.
