Results 1 to 17 of 17
Thread: I understand why ppl rock strectched tires now!
    ATL, GA
    Default I understand why ppl rock strectched tires now!
    I am sitting pretty low on coilovers and with my 245/40r18 tires I am scrubbing like a bitch!!!! The smallest bump make me scrub, especially in the rear cuz the outside edge of the tires is hitting inside the wheel well....is I had some 225/35r18's i would prob be fine!!!
    So basically if you want to sit low and eliminate wheel gap you almos have a little bit of stretch so you don't rub the fender or wheel well...
    I already rolled your fenders too man...
    O_o
    You need some stretched tires ASAP!
    Have fun replacing those axels hehehe
    ATL, GA
    Quote Originally Posted by JessAlba452 View Post
    O_o
    already replaced the drivers side...still has this subtle clunking/crunching feeling/noise so im gonna install the new pass side axle tomorrow. I was hoping the drivers side would fix it 100% but nope...oh well
    where can I get some 225/35/r18 for the low low!!!!
    FYI 235/40/18s stretched on my G35s...keep that size in mind
    Or there is the alternative that is the PROPER way:
    A. Raise the car
    B. Fender flares. REAL ones not those stupid bolt over the stock one shit.
    Weekly Gwinnett/Junciton Meet
    next options will be to pull the fenders.
    kangarooster meadows
    Eh there really isn't anything wrong with a little stretch. Some people just take it way too far.
    WillAgreeForReps!!
    The Town of Lula
    tire stretch, like most things, is good in moderation
    ALL CAPS JITB's Avatar
    lol man ive been trying to tell you.. what width are ur wheels?
    but i dont think you need to put a stretch tire on ur rims, you may just invest in some eccentric bolts, and add some camber. Or try lowering it some more, and see if you get some more camber out of the rear.
    i think the g35 wheels are what 8" wide? dont think that will really do much with a 225..
    ATL, GA
    Quote Originally Posted by JITB View Post
    My wheels are 18x8 with 245/40s
    I'm not going to stretch my tires, but I am going to get some new wheels, 19x8.5 with prob a little stretch such as 235/35 or something..and no neg camber for me
    Quote Originally Posted by NissanTun3r View Post
    that 235 on that 8.5 equals 0 stretch.. if you want to stretch on that 8.5 your gonna have to go down to a 205-215 atleast.... But its not neccesary. I gurantee if you lower the car some more when your fixing the axle. Physics will kick in , and you will get a bit more camber out the rear.
    And for the front i will advise just a few degrees of camber, to fix it. Because that tire size you are talking isnt gonna do anything.
    dont let hellaflush/stanceworks etc. out weigh physics! its how suspension works!
    ATL, GA
    1) The tires around my 8 inch wide wheels are 245 mm wide and they sit flush, perfectly flush with my wheel, with that said how would putting 235's on a wider wheel(8.5) not stretch it? I do not want a lot of stretch, only a little bit, and I mean a little...
    2) I have camber plates in the front, and as of yet have not had to use them. I am pretty low and my camber is fine. coilovers ftw
    jus sayin
    Forged Performance Sharif@Forged's Avatar
    Marietta, GA
    Nail your offsets, roll fenders, and dial in some camber and you don't need much stretch.
    Jan 2010
    Macon,GA
    hondas can get away with jus lowing to get rid of scubing not nissans just my
    jus sayin
    it depends on the tire, but a 235 on a 8.5 isnt gonna fix what you want. There is another half inch that you dont see on regular properly fitted tires. and it doesnt begin to truly stretch until you get down to a certain width.. and with the 8.5 its the 215-205..
    here is a pic of a 225 on a 8.5 with a falken tire, and they are known to stretch good. What you need is some camber to fix this problem.. with the stretch your still gonna scrub. drop the car more.. and you will see
    Quote Originally Posted by wanganU13 View Post
    most modern cars can also.. the honda has no special powers!
    I love it when critics realize that in fact, there is a reason behind all things. Welcome to the Other Side.
    Garage-Sixgun
