Results 1 to 11 of 11
Thread: Throttle problem!
    Nov 2009
    Default Throttle problem!
    Ok I bought j-rocks civic from him and have spent almost 200 on parts to make it a safe dd. I bought a cv axleand then my timing belt broke and I got it fixed and it drove fine for 2 days but now its like I have to push the gas pedal all the way to the floor before it starts to rev up. I think the throttle cable is stretched but I don't know. I need some help with this problem before i go spending more money then I really need to. I have to push the pedal all the way to the floor before it starts to rev up.
    So what could it be?
    Oct 2008
    adjust throttle cable @ throttle body ....i believe 2 13mm wrenches will do the trick
    12mm, but it might also be a tps problem. I'd check what it looks like with the intake off with someone else giving it WOT in the car and see how far it opens up. If so that might be your problem.
    My line of work
    www.internationaljets.com
    Nov 2009
    Yea checked where the cable was hooked to the throttle body and tightened it down and it fixed my problem. So glad I dont have to spend more money on this thing........"Knocks on woodgrain!"
    recheck the timing belt make sure its still on point.
    when you mash the pedal down , slowly does it rev but takes for ever or it only revs until it is to the floor????
    sandy springs
    sounds like it may have jumped time
    Nov 2009
    Quote Originally Posted by ASE*Tech View Post
    It takes forever.
    Quote Originally Posted by Quickfeet View Post
    It takes forever.
    either jump timing or bad head (bent valves)
    For all the people answering what you think his problems are, he already fixed it, which is fortunate.
    My line of work
    Nov 2009
    Quote Originally Posted by Starrfire View Post
    Yeah i got it fixed and then rechecked my timing so its all good now. Thanks for all the thoughts on the problem.
