For the most part I try to figure out my issues myself due to #1 like to figure stuff out on my own and #2 dont want to get the bash treatment. So I search my ass off prior to asking anything.
Anyways here is my problem. My car has been running perfectly fine for months (s14 w/ s14 sr swap). Just this past weekend when I got off work, I got in my car to go home, my car wouldn't start. Got a hammer and started tapping on my starter, started right up. I get home and later on that evening I have to move my car so my wife could go to work. Again car won't start. I pushed the car onto the side of the road so wife could leave. Next morning I go and do some inspecting, my ENG fuse is blown in the fuse box next to the battery and my ground wire came off of my starter, I attached the ground wire replaced the fuse and. Car started right up so I pulled it into my driveway, little didIi know it did not want to shut off. When i pulled it into the driveway car threw a code 11-CAS, but I reset the ecu to see if it would do it again...nothing, just a solid 55 now. I've been putting up with that for a week now. I did replace the ignition switch still same issue. Now today I was headed to get my car tuned I filled up my tank and my car wouldn't start when i was ready to go. About 15 min at the pump I got the car started drove to Walmart to see my wife and let her know I was headed for a tune. Back to my car it wouldnt start again. I checked all of the fuses nothing is bad. After I unplugged my ignitor and plugged it back in car started up, I turned it off to see if anything, wouldn't start again. Got it started again and just brought it home. Now it wont crank up. So if you guys can throw in some input so I can check every possible solution that would be fantastic. Problems again so you dont have to read my story. I have been searching all week and am still in the process now as im writing this so please don't think I'm kicked back waiting for answers.
-car stays running with key out of ignition in off position/dash lighst stay on (i.e. seatbelt, eng, door ajar) radio goes off. for some reason engine is still getting fuel
-items replaced, fuses & ignition switch
-car wont crank up (possible ignitor?) starter wont click either maybe starter issue? CAS? also i just read that if the Crank Angle Sensor is faulty, i wont permit the starter to engage? anyone know of this?
I'm sorry for the story all but thought I should be as detailed as possible.
