Thread: jdm twin scroll parts
    import/domestics
    Tampa, Fl
    Default jdm twin turbo parts
    i bought a jdm twin turbo motor i am putting in my wrx wagon. im stripping it down to a long block and selling the rest.
    vf20 a little shaft play but bad seals $20
    vf21 a little play good seals $50
    twin turbo ej20 exhaust manifold $80
    powersteering pump w/resvoir(pulley is bent
    from where they pulled the motor) $30
    alternator $50
    throttle body $25
    there will be more but thats off the top of my head along with parts from my old engine. you can call me at 678-755-2272 thanks for looking.
    well at least the motor is still good
    93 Firebird Formula
    99 z28
    Weekly Gwinnett/Junciton Meet
    DIBS i'll take the turbo and manifold, and throttle body.
    import/domestics
    Tampa, Fl
    turbo or turbos its a twin set up. give me a call. need the money finish my car
    93 Firebird Formula
    99 z28
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    twinscroll =/= twin turbo. Which is it?
    Correct Fitment Crew CEO
    Because Only Turds Should be Dumped and Flushed.
    2012 Hyundai Veloster / 1960 Fiat 600D
    import/domestics
    Tampa, Fl
    its a twin turbo set up from a jdm legacy . the manifold runs from side to side like a usdm but has a turbo on each side of the motor with down pipes on each side. 1 spools for low end and 1 for top end
    93 Firebird Formula
    99 z28
    WazzySpace.com wazzyatl's Avatar
    N. Atlanta
    steve, its a twin turbo NOT twin scroll.. twin scroll turbos are totally different!
    UNLESS your turbos look like this
    http://cgi.ebay.com/IHI-VF45-Turbo-T...item1c0e411f79
    Dining in Hell
    Quote Originally Posted by Camaroz2869c View Post
    twin scroll is the factory set up thats why the turbos are different sizes but you could use the minfold to do a twin set up.
    its a twin turbo set up from a jdm legacy . the manifold runs from side to side like a usdm but has a turbo on each side of the motor with down pipes on each side. they call it twin scroll because 1 spools before the other.
    Then it's a sequential twin turbo setup, NOT a twinscroll turbo.
    import/domestics
    Tampa, Fl
    corrected the listing but the headline wouldnt change
    93 Firebird Formula
    99 z28
