Results 1 to 5 of 5
Thread: Does 92 cb7 and 93 prelude use the same clutch??
    Senior Member AMD_Civic's Avatar
    Default Does 92 cb7 and 93 prelude use the same clutch??
    HAVE A BUDDY WHO PUT IN A 92 ACORD CLUTCH INTO HIS 93 LUDE, SOMETHING BOUT HIS CLUTCH SLIPPING WHEN THE CAR IS HEAT UP DRIVING DOWN THE ROAD, BUT WHEN IT COOLS DOWN THEN ITS ALL GOOD AGAIN.? SO ARE THE PARTS INTERCHANGEABLE OR NOT??
    they are interchangable, you might wanna try adjusting the clutch pedal. and did he install the clutch correctly???
    About to approach beast mode
    im not sure i just know what he told me... and then checking autozone and all that the item numbers are different also...??
    Quote Originally Posted by K24cb7coupe View Post
    they are interchangeable, you might wanna try adjusting the clutch pedal. and did he install the clutch correctly???
    x2
    Item numbers might be different, but they're the same. Same tranny used for most the accord/prelude F/H series.
