Results 1 to 19 of 19
Thread: 1990 miata ticking issue
    douglasville
    Default 1990 miata ticking issue
    ok so i just put a header on a few minutes ago and now it has a really loud tick. everything seems very tigh and i used new gaskets. it had the normal valve tick before the header, could installing it just have made it louder? or can a exhaust leak sound like a tick?
    (RAH)² (AH)³
    your pistons are fucked!
    I asked a girl if i could buy her a drink, she said I have a boyfriend, so I said, well i have a goldfish, she said what? I replied, oh I'm sorry I thought we were talking about shit that doesnt matter.
    douglasville
    Quote Originally Posted by DecoyOctopus View Post
    doubt that very seriously
    ^^this guy loves you jdm-civic's Avatar
    the sky
    some thing happened to my boys civic. i guess since your going from thick cast iron to thin wall steel it doesnt absorb as much sound......he been normal eber since the change
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Is it new? A crack in the header or somewhere high in the exhaust stream can make a ticking sound. What brand is it? Is it a head tick or knock in the bottom end?
    If it just started it's probably an exhaust issue.
    (RAH)² (AH)³
    Quote Originally Posted by dohc4.6sc View Post
    lolololol your miata has pistons?
    I have a miata, also. i think it just got louder because of your header
    Does your Miata NOT have pistons?
    (RAH)² (AH)³
    lol, I swear I thought he was talking about a rx7
    ALL CAPS JITB's Avatar
    mazdas b series motors B6 1.6 dohc, and the bp 1.8 dohc, have crazy valve lash. Oe rthe years, but i noticed it more when the car is low on oil. And or the car has sat for along time, or in cold weather.
    but you can help it by running some sea foam or gum out on the valves, or take the valve cover off, and get a tooth brush, and go at it head to head, with some gum out.. and flush it...
    but it could be a shitty gasket... since it just start happening.
    no.
    Right, I hope you're kidding......
    douglasville
    its new, its some ebay brand(i know i know) and its a head tick seems like its the loudest right around the firewall
    Check the header for a leak, if there is a tiny crack in the header, especially around the runners, it will sound just like a ticking or even a knocking motor. The crack will worsen and you will swear the motor is about to explode.
    douglasville
    i forgot to mention there is no o2 in it right now, couldnt get the old one out but the header came with a plug for the o2 so i installed it for now, could this cause a tick at all?
    Yes, it could. Take the plug out and see what it sounds like.
    douglasville
    what should it look like? i mean its steel and actually screws in so i thought it wouldnt do anything but dump fuel till i got a new one.
    Well if it's leaking then it could make a ticking/knocking noise.
    douglasville
    my bad i thought you said what it looks like, fast reading fml.
    rollin 91 da egpower904's Avatar
    Dallas, GA
    what he said about the o2 sensor bolt. that ticking will keep going until the bolt pops out, the sound is it loosening itself. i heard that same noise from the ebay header i put on my eg8 a year ago, it had the top o2 bung in the engine bay, and one on the bottom of the header near the collector. i didnt tighten the bottom one all the way (forgot to) and going down the road i hear ticking for about 5 miles then POP!! bolt shot up into the floorboard scared the shit outta me. loosened itself out.
    DA SQUAD MEMBER #70
    91 da/95 gsr/boosted/awaits tune....
    Or you thought your Miata had a rotary until you googled it....
