JDM Legacy Steering Wheel - $200
I received this as a gift from a friend and from what I can tell it is a JDM Legacy wheel. The splines and threads are all intact. The only part that isn't minty is the top of the steering wheel that you can see in the one pic. This matches the OEM optional shift knob too! You should be able to bolt this right up with no modification AND use your cruise control setup with a little modification (although do your research first to make sure that it will fit your specific car)! http://forums.nasioc.com/forums/show....php?t=1447670
