Results 1 to 17 of 17
Thread: Failed emissions NOx/HC help
    Newnan
    Default Failed emissions NOx/HC help
    just had a magnaflow cat and resonator put on today, thought it might pass emissions, of course it didn't.
    25/25 test
    -hc - reading 00272 allowed 00160
    -no - reading 03162 allowed 01179
    50-15 test
    -hc - reading 00260 allowed 00166
    -no - reading 03327 allowed 01304
    car doesn't have an egr system anymore, even the iacv has been ruled out. not sure what all was done previously, just was told the ecu was chipped by scotty. any suggestions on how to pass? I was reading to run high octane and retard the timing. no cel's brand new cat. drivetrain is a b18c1 and higher comp. pistons yeilding roughly 11.45:1 comp ratio, I also read higher compression creates higher nox levels. any helpful info would be greatly appreciated.
    raggedy volvo owner
    nox is usually created by heat so cooling your intake charge can help. You can do this by richening the mixture, but this may also bring up your HC and/or CO. You didn't fail by much, but without EGR, the nox will be a tad high. Water injection helps (if you're into rigging this up), as does running a bit of methanol or denatured alcohol through. Combustion chamber temps are probably too high.
    My car is factory....
    Every single performance part and or modification it has was made in a factory somewhere.
    Newnan
    thanks i will look into those. now this might sound stupid but, if I turned fuel pressure down and retarded the timing could that solve the problem? less gas out the tailpipe and retarding the timing to run cooler right?
    Jan 2010
    Fayetteville, Georgia
    Don't mean to thread jack, but care to run one day?
    Quote Originally Posted by greasemunkey View Post
    I do this EVERY year, I will get my emissions done without messing with my fuel pressure (42psi daily) and I will only pass like half the tests. I then come back another day and turn the fuel pressure down ALL the way and it pasts every single time. I'm currently running a Magnaflow high-flow cat. Of course I still have all my emission devices too though.
    RedHenRacing #02 Stuntman G's Avatar
    Jul 2009
    Haha I beat your score . . . . my cat-less Supra did over 5k in both of the -no- tests lol
    INSIGHTFUL DIALOGUE ANALYSIS: Actually, Hector, that is not what we call valet parking. Valet parking is where someone parks your car for you. You just pulled your car up to the front of the store and got out. We just call that parking.
    I MAKE THESE
    Newnan
    retard that timing bro lol, unless your just reallly freaking high compression
    Newnan
    Quote Originally Posted by Destineal View Post
    depends, what ya runnin?
    retard the dizzy timing. it will lower cylinder temps by alot
    Newnan
    but then i have more unburnt fuel
    Newnan
    im just going to advance it a bit and run 2 bottles of heet(methanol) on a half a tank
    IA Member afp6171's Avatar
    augusta,ga
    get good SP wires(Accel) switch to E3 plugs and put your timing to factory spec. e3 plugs are provein to lower NO2/CO2 and add a few horse power. try it be astounded...
    retard it just for a few minutes, when your done with emissions you can go right back to where you were.
    25/25 test
    50-15 test
    did i just chip it, or did i also dynotune it? o2 sensor enabled/working? try running the car for a while on the highway to really heat up the cat. mark the dist and retard it all the way. go pass. of course if i just chipped it w/ a basemap then it needs to be tuned first otherwise you'll probably be wasting your time.
    Newnan
    no o2 it has been ruled out of the ecu, i do not know what was all done tuning wise, I was just told chipped
    JDM TYTE AnthonyF's Avatar
    I can help if you aren't looking to fix. PM me.
    -Ant.
    The Carbon Fibered R6
    if not tuned then higher likelyhood it'll fail. o2 deleted w/ increase chances of failing since the emissions test takes an average reading of the ecu correcting rich/lean. you could possibly pass w/ the steps you're taking and possibly pulling the timing all the way back.
