Thread: valve cover bolts breaking off
    bluej1
    Aug 2009
    chatt
    Default valve cover bolts breaking off
    ok I have a huge prob.
    I have 3 count them 3 bolts broke off in my head from the valve cover bolts is there anyway i could get them drilled out and put a diff. bolt in there. I have put the gasket maker on there to slow the oil from coming out so...... any ideas ????????
    IA Member SRK420a's Avatar
    Lithonia,Ga
    Quote Originally Posted by nateej1 View Post
    Compare a drill bit to the valve cover bolts, go one size under, drill them out, wedge something in the hole you make and carefully unscrew the remainder. This just mite be smart enough to work
    Just be careful and stay in the middle of the broken bolts so you dont hit the screws walls.
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Drill them out and re tap the holes. Better make sure to get someone with some experience to do this for you.
    Lithonia,Ga
    Quote Originally Posted by TSiFTW View Post
    or what he said
    bluej1
    Aug 2009
    chatt
    thanks
    GWINNETT IS GREAT!
    PLZ PLZ LET PROFESSIONALS HANDLE THIS!!!!
    thanks
    good luck
