Results 1 to 23 of 23
Thread: Walbro 255
    it's true! QD my fav tmracing83's Avatar
    Rockdale, GA
    Default Walbro 255
    So I've got one on my srt4 I just got.
    I haven't taken the car to a shop and had it checked out or anything, this is JUST what the previous owner told me.
    He told me once we traded that he FORGOT I mention how I shpuldn let my gas level get below a 1/8 tank because of the walbro, he said the car starts to sputter. I'm not testing him, I fill up at a 1/4 tank.
    HOW WOULD I GO ABOUT RESOLVING THIS PROBLEM?
    Sorry for the long story.
    And thankyou in advance!
    OBAMA..... *IS*
    One. Big. Ass. Mistake. America.
    Rockdale, GA
    Also I have a areomotive a1000 fuel pump. If that helps or matters
    OBAMA..... *IS*
    install the fuel pump correctly and it shouldnt be an issue
    Rockdale, GA
    If I installed it, it wouldn't even work at all. Don't be giving me that much credit.
    I guess wherever I can get my shit times they can check it out. And emmino
    I have no clue what a commander is so I guess y'all can't tune it
    OBAMA..... *IS*
    It is a little hand held device that the diablo sport uses, if you dont have it I cant tune it, sorry... but I can tune all the other devices for the srt's... we are finishing up build 2 of them now hoping for 500+
    Rockdale, GA
    I'm looking for 350 tops. Just my daily.
    OBAMA..... *IS*
    Rockdale, GA
    I have the diablo tuner and a cord that attaches it to the car. If not diablo. What do I need like AEM or wat?
    OBAMA..... *IS*
    hmm ill look into it, and what you have is good, we just never got the stuff because it wasnt very popular until lately w/ srt's. we use aem fic, aem, dtec, afc, greddy
    Rockdale, GA
    My bday is n the middle of feb. So if it doesn't work out I may get one of those. Which would y'all recommend?
    OBAMA..... *IS*
    Rockdale, GA
    Anyone else have any input other than install it right?
    I've seen people having this problem before with the walbro
    OBAMA..... *IS*
    Where Am I
    I always heard the Diablo is the best, cause its not a hack but a reflash of the ecu.... But the fuel pump wasn't installed correctly because it does that, idk u can test it but thats what I was told too.....
    Rockdale, GA
    Quote Originally Posted by Turbodude06 View Post
    Who installed it?
    OBAMA..... *IS*
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    to be honest, you shouldn't let it get that low because you will also start to suck up trash and clog the injectors and such. also, being submerged in the fuel is how the pump stays cool.
    N/A>>><<<BOOST
    Rockdale, GA
    Quote Originally Posted by RUFFIAN View Post
    Shouldn't let it be how low?
    There isn't a way to fix this problem so that I can actually run a full tank of gas?
    OBAMA..... *IS*
    in your nightmares
    Quote Originally Posted by tmracing83 View Post
    In the first post you stated that the owner warned you not to let the fuel get below 1/8 of a tank I.E. damn near empty. That was what I was referring to.
    N/A>>><<<BOOST
    Rockdale, GA
    Ya I didn't know if you ment 1/8th or 1/4
    If u read above I said I fill up at 1/4 tank
    OBAMA..... *IS*
    Unregistered User Member31410's Avatar
    I let my car go well pass the 1/8 mark all the time with no issues. As the others have said, it could be just an improperly installed pump or the fuel canister wasn't aligned properly so the gauge is off. The latter is a very common noob mistake. There is an arrow on the outside of the fuel canister (it may be hidden by the mounting ring). This arrow needs to point straight up to the sky, perpendicular to the ground.
    The only issue with the Neon/SRT-4 model Walbro 255 I know of is a pressed metal piece on the pump falling out. I've encountered the pin issue twice already in the last three years.
    http://www.srtforums.com/forums/f187...notice-506522/
    2005 Dodge Neon SRT-4
    Rockdale, GA
    Damn!^^^
    Thanks for the warning.
    What are some of the symtoms(sp) when the pin comes out?
    And to fix do I just reinstall the pin or do I need a new one. If it falls out I'll prolly never find it with my luck
    OBAMA..... *IS*
    Read that thread I posted to learn more about it. In most cases, you can hear the fuel pump priming but no fuel makes it to the injectors. From what some people have said, you can push the pin back on. In both my cases, I ditched the failed ones since I didn't feel comfortable using them anymore. When the metal piece falls out, it'll be contained inside the fuel canister. It will rattle around when you handle the fuel canister.
    Rockdale, GA
    Quote Originally Posted by Member31410 View Post
    Can you buy new pins from walbro?
    OBAMA..... *IS*
    I haven't heard of anyone doing that. The pin will be contained inside the fuel canister if you want to reuse it.
    Rockdale, GA
    The threat was pretty damn useful. Thankyou for the warning about that.
    OBAMA..... *IS*
    Rockdale, GA
    Ya I read that. I'm guessing the cannister is in the back bottom of the car by the tank.
    OBAMA..... *IS*
