Results 1 to 13 of 13
Thread: want to remove badges, worried about badge holes
    ZOMG ChnkyLao's Avatar
    Winder, GA
    Default want to remove badges, worried about badge holes
    I want to remove my badges off my sc and was wondering if there was a way to plug and paint the badge holes cleanly?
    banned mother fucker
    far away
    well there's one way i saw it done,you get some drywall anchors and fit them in the hole to make sure they fit tight. if they do, fill them up with caulk or silicon, paint them, then before you put them in spread some silicon around them so it will be sealed. it work, and didnt look to bad as they sat flush. and sealed good. if you didnt want to fill it with bondo and paint it.
    Новак 5speed's Avatar
    Conyers, GA
    What kind of car, not all have holes?
    Amen.
    IA Member SRK420a's Avatar
    Lithonia,Ga
    Quote Originally Posted by 5speed View Post
    Yea what he said because it could be just an adhesive behind the badges
    Conyers, GA
    First just take a blow dryer and set it on its highest heat and blow and let the badge area get hot. 5 mins or more will do. Then take fishing line or dental floss and run it under the badge and slowly remove it. Clean it from there and fill in the hole if there are any.
    Amen.
    Winder, GA
    its an sc400 there are hole behind them, what would i fill them with? bondo?
    Lithonia,Ga
    Quote Originally Posted by ChnkyLao View Post
    GOD NO.....Bondo would just sit there and crack of break off because there is nothing for the bondo to grab on. It would just drip down the hole on the inside of the car
    Middle, Ga
    Have someone with fab experience weld the holes in. Then filler, sand, primar, and paint.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Where Am I
    Quote Originally Posted by NVM View Post
    ^Yea weld them or put a peace of medal behind it and weld it to it, so u then can bondo the rest and it will have something to grab on to. Then sand, primer, and paint it....
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    Quote Originally Posted by Turbodude06 View Post
    I wouldn't do it until you can do it this way. Just leave the badges on until then or its gonna end up looking like ass.
    Winder, GA
    i wounder how much a body shop would charge to do this
    far away
    a shop would probably charge, id say about 150-200
    yo son RallyMazda01's Avatar
    Dec 2008
    Snellville G.A
    as i recall i didnt find ay on my sc.
    i took the sc400 badge off and both rear and front lexus badges. no wholes.
    replaced them with Soarer emblem and the griffin emblem
    1995 Sc470
