Results 1 to 14 of 14
Thread: going turbo
    Default going turbo
    ok so iv been thinking and have decided to go turbo. im 18 and only making minimum wage so i kinda am on a budget. iv been thinking about an egay turbo kit for starters and upgrade from there or just keep saving my money. i dont plan on making big hp numbers, plus its going to be my dd and i wont be racing. my gsr is basically stock, just a couple of bolt ons.
    any helpfull advice is appreciated
    Jul 2009
    get your tune money first then start buying parts....
    all in all read "my turbo build" in this area..... it will be helpful for you.
    it was his first turbo kit and he got it done almost.....
    were here for ya
    Aug 2009
    DOUGLASVILLE
    go ebay kit, make sure you get a log manifoild kit though, and yea make sure you save for tune money aswell, i have got 3 buddy's with the ebay kits and the not under 200hp. just later upgrade the wastegate and the bov, and mainfoild. then turbo lastly!
    the ecu i have now is chipped and tuned already. i think. idk wat its tuned for tho
    Out in the Boonies
    Quote Originally Posted by CautionMeDC2 View Post
    Doesn't matter if it's tuned already. After putting on a turbo you'll be running under different conditions which will requie another tune. So you should at least have $300-$400 extra just for the tune.
    Senior Member EJdm's Avatar
    boosted is fun but pricey....
    so iv heard thts why im still iffy about it. i plans were to jus go n/a but everyone around where im at is going boost, so i said f**k it me too
    revolution big mac's Avatar
    do it right the first time if not dont do it at all. i had to learn the hard way. i got spare turbo parts if you need for cheap so let me know. if you need advice or anythingh
    Quote Originally Posted by big mac View Post
    i will keep tht in mind. plus your like 30 mins away from me.
    where are you from man?
    gainesville
    aight cool i see
    kangarooster meadows
    Keep saving your money and buy quality parts. If you want to save money, do it with your FMIC kit. Ebay ones are generally fine. But most of those kits aren't going to come with everything you need, you have to setup your oil return lines and whatnot, and ebay kits usually don't satisfy a car that isn't setup for boost already. Plus considering engine managment and tuning, it adds up to be costly if you want to do it right. Take your time and try to find good used parts if your low on money.
    im in the same boat you are. im 18 and i want to boost my car as well. at 1st i was going to re-build my current engine but then i started seeing good deals on parts so i started buying and saving. ive been buying stuff here and there since october and everything is finally coming together. basically do what every1 else said, save your money and do it right. it will be worth it in the long run b/c once you have a boosted car i hear you start wanting more boost. but its all up to you. GL
    damn, i want that penis
