Thread: help with my crx
    Default help with my crx
    wuts sup i have a 90 crx si my hood latch cable is broken any suggestions on wat to do and how to fix?PLEASE HELP GUYS
    thanks
    *NY Driver* CeOTiO8's Avatar
    In your girl
    Quote Originally Posted by 88SI View Post
    thanks
    GOSH.... This might help.... If the cable is still good by the hood... set it up a way you can pop it up from the outside of the front bumper Sorry I suck at explaining things
    PROUD SUPPORTER OF BAM-TECH WTF?
    not old....classic!
    Jan 2010
    Lawrenceville, GA
    if the latch is broken... try pull-a-part. if the cable is broken, tie a coat hanger on it right next to the latch and leave it out by the grille so you can pull on it from there. if the plastic clip is broken up on the dash, vice grip the cable and leave it down by your feet and pull it when you need it.... wouldnt recommend trying to replace the cable.... it is a royal pita!!!!
    Jan 2010
    north ga
    ha, i got the same problem with my trunk cable. except i can open it with a key. haha. good luck fixing that
    Sep 2009
    Columbus
    man its not hard at all, just follow the wire from the latch to the hood, (it should be runnimn through the driver fender) i did mine in 10 min
    The Doc DrCRX90's Avatar
    Sep 2008
    My garage
    ^werd a new hood cable from honda is 52.75 with employee discount
    DTFKr3W?
