Thread: Cold Start Up Issue Del Sol Content
    Souf Wess ATL
    Default Cold Start Up Issue Del Sol Content
    Not a terrible issue right now, but whenever I do a cold start up, the motor revs up and down around the normal cold start RPM's. It doesn't just sit there like normal. I'm not throwing a code, so I'm assuming that it could be an IACV problem.
    I was just wondering if others came to the same conclusion as me.
    If there is anymore info you guys need, just lmk.
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    i think its because you need to paint your lower grill' black
    stock ecu or chipped? tuned or untuned? stock or modded engine? what's the setup? as much info as possible would help.
    Titties!!!
    Quote Originally Posted by scttydb411 View Post
    check out the fast idle thermo valve under the throttle body, since it is only doing it when it's cold that is the part that controls airflow until it reaches normal temp and the ecu come out of closed loop mode and the IACV starts to do it's job. there is a plunger in there that you heat up and if there is no movement then its bad i think if i remember correctly.
    Souf Wess ATL
    Stock ecu, untuned...stock internals, intake, exhaust, test pipe...B18b1 obd1 motor.
    I don't pull out... E=MC˛'s Avatar
    Where we like our sisters...
    http://www.honda-tech.com/showthread.php?t=1564019
    follow this and you should be good.
    Souf Wess ATL
    Quote Originally Posted by E=MC˛ View Post
    Thank you sir, I'll check it out tomorrow! Reps
    x2
