Results 1 to 2 of 2
Thread: my 88 integra build
    my 88 integ 88integracer's Avatar
    Chamblee Dunwoody
    Default my 88 integra build
    i'm jus lookin for some help and some opinions on what to put in it i want to use the same engine. I did a lil lookin and found this
    D16A1 ZC DOHC non-vtec Found in: 1986-89 Acura Integra (USA)
    Displacement : 1,590 cc (97 cu in)
    Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
    Valvetrain : DOHC (4 valves per cylinder)
    Fuel Control : OBD-0 MPFI
    1988-1989
    Compression : 9.5: 1
    Power : 118 hp (88.0 kW, 120 ps) @ 6500 rpm
    Torque: 103 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
    Piston Code: P29 (Equivalent to PM7)
    ECU Code: PG7
    L3 Gearbox - Cable Tranny
    so now jus lookin for a lil help on where to start my bilud for more hp and torque all motor and then turbo latter THANKS FOR YOU OPINIONS
    SwiperNoSwiping!!
    hm.... if anything, i'd look into what swaps you can put in that chassis unless you're interested in actually building a D series
    u remind me of a wigger !
