i'm jus lookin for some help and some opinions on what to put in it i want to use the same engine. I did a lil lookin and found this
D16A1 ZC DOHC non-vtec Found in: 1986-89 Acura Integra (USA)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Valvetrain : DOHC (4 valves per cylinder)
Fuel Control : OBD-0 MPFI
1988-1989
Compression : 9.5: 1
Power : 118 hp (88.0 kW, 120 ps) @ 6500 rpm
Torque: 103 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
Piston Code: P29 (Equivalent to PM7)
ECU Code: PG7
L3 Gearbox - Cable Tranny
so now jus lookin for a lil help on where to start my bilud for more hp and torque all motor and then turbo latter THANKS FOR YOU OPINIONS
