Thread: need help please
    bethlehem
    Default need help please
    okay i lowered my civic and i mean i dropped it to the ground and the rims i had on there were 17 inch rims the tire size was 205/40/r17 and the inside of the tired was geeting ate away like it was eating it like at a 90 degree angle on the inside of the tire and i was wondering if that was because the tire was to wide for the lowness
    vanilla sky.
    probably needs alinement,camber kit,shocks and now tires.
    bethlehem
    Quote Originally Posted by silverDA View Post
    i am putting smaller tires on it to because it literally was an l shape
    like this
    top of tire
    ________________ this weird cuz it is like somebody cut a 90* angle
    ________________
    ___________________
    ___________________
    ___________________
    i really think it is a tire that is to wide because i have some smaller tire and it is not doing it
    =) JF868849's Avatar
    Oct 2008
    BYRON
    camber kit
    bethlehem
    Quote Originally Posted by JF868849 View Post
    camber kit
    okay i myself know i need a camber kit i already know and am looking at one but what would be rubbing and ripping the wheel off so exactly what could be touching it
    Senior Member Patterson's Avatar
    Summerville
    The road is touching it. the inside of the tire is the only thing its riding on. so it will eat up some tires quick. get a camber kit and go straight to an alignment shop to correct the problem. but now you need tires too
    IA Member SRK420a's Avatar
    Lithonia,Ga
    Buy a camber kit. you need an alignment bad lol before you wear out the next set of tires
    BoostedEG civicmantim's Avatar
    stockbridge,ga
    If your camber is out that bad then the toe is also out which proably has your tires pointing out on both sides this will definitely chew up some tires, so yes like everyone else said you need an alignment.
    bethlehem
    okay i need an alignment and stuff but the fact that i have seen cars lower than mine with no camber kit and more camber than mine an the tres dont look like these did when i took them off
    Summerville
    Quote Originally Posted by HoNdApOwEr View Post
    do you know what camber and toe being out can cause? hell a buddy just had NEW tires put on with this problem and 1 week later there is no tread left. just saying
    bethlehem
    okay i am gonna try to get a pic up of the tire becaus ethis isnt normal camber and toe tearing the tire up trust me i know bout toe and camber and the tire wear that it causes i did my reasearch before i posted asking what it could be
    bethlehem
    okay i am gonna try to get a pic up of the tire becaus ethis isnt normal camber and toe tearing the tire up trust me i know bout toe and camber and the tire wear that it causes i did my reasearch before i posted asking what it could be and i also put some smaller tires on there now and it is not eating the tread like it was on t
