Results 1 to 13 of 13
Thread: break lines
    JDM-EJ1 shadowx3's Avatar
    G-County
    Default break lines
    aye bro .:Stirfry:.'s Avatar
    i knoe you can get the hard lines from autozone, or both at summit
    ATL DAsquad Member #9
    G-County
    break lines? what about them things i circled in the pics?
    G-County
    any way i can use my old ones?
    yea just re bend them.
    Certified Gearhead 94ej2's Avatar
    Mobile, AL
    bulkhead fitting
    http://www.summitracing.com/parts/AER-FBM2769/
    then you need the -3an bulkhead nut.
    G-County
    any good bender that works?
    Smyrna, GA
    GrandmasterFlash.com should have some "Break Lines"
    PURP-a-trader PURP's Avatar
    "BRAKE LINES"
    It is in the back of AutoZone where they keep the belts, hose and such. I can't remember the correct size, but it's like 14 bucks for a decent amount.
    Find out what AN fittings you need, how many, etc..etc. You will want -6 to be your main size. Get yourself a bender, flaring tool, and cutter. Then have someone who is experienced in the field, help you. Summit will carry all the AN fittings that you need.
    Make sure you draw out how you want your system to run and figure how many "T's" you'll need, fittings, how your bends will run... blah, blah, blah. And make sure you use a proportioning valve that is NOT for ABS.
    I'll try to find out what size line you'll need. But I do not recommend reusing the old lines.
    G-County
    why not use the old lines?
    G-County
    are these the size for the civic break lines?
    Quote Originally Posted by 94ej2 View Post
    bulkhead fitting
    G-County
    what is the bulkhead fitting size on the civic i need to use?
    G-County
    any more help????
