Results 1 to 21 of 21
Thread: 90 integra wont crank
    Senior Member EJdm's Avatar
    Default 90 integra wont crank
    okay so my cousin gave me a 90 integra with a blown tranny...after installing the new trans and everything else it wont start, crank or even make any clicking noises but all my lights in the cluster turns on...i tried jumping it with cables and push starting it thinking i had a weak battery yet nothing...double checked all the wires and grounds...what could it be???
    yuuummmyy
    Dec 2008
    check if you got any power. it may be the dizzy. or how's the starter?
    Quote Originally Posted by EJdm View Post
    "Bacon And Cheese"
    Got Vtec?? BigDsGTP's Avatar
    Jan 2010
    Monroe, GA
    Triple check the wires!!
    Especially the starter wires, the transmission ground cable and the ground cable to the valve cover.
    Chickens Eat Eggs
    south side hoe
    yep check the tranny ground ...and if its still not clicking check the main relay,cuz the car should start even if the starter and battery is bad if u rolled the car a and clutched kicked it
    i got power horn works radio works just seem like not enough but we tired to jump it with cables and even push it....yup checked all the starter wires/ground....i know that the trans ground is on and the VC ground is missing but would that cause it??? imma go look for my old ground kit and hook a few grounds up later today see if that helps...
    also i realize that 2 of the injectors are not on tight...one is lose idk how but clip is on and the other missing the clip...
    yuuummmyy
    Dec 2008
    check to see if you got any sparks.
    "Bacon And Cheese"
    *NY Driver* CeOTiO8's Avatar
    In your girl
    Where you located?
    If your close by me I don't mind stopping by and helping you
    shoot me a text 404-452-9158
    PROUD SUPPORTER OF BAM-TECH WTF?
    im in winder so if any1 has nothing to do and want to help...text you ceotio8...i work 2nd shift so i will be leaving around 2pm...
    Southside Ridin HATCH
    check ALL grounds..
    hey, check if you got any sparks. like plug up with spark plug to the wire and tap it to the ground? to see if you get any spark. if not, it's your dizzy or wires. that's wat happen to my car when i swapped it. also, when my bro-n-law changed his clutch, we accidently wired that starter wrong, that's also maybe another reason.
    i'll check for spark but then again doubt it bc i motor wont even turn over...and about the starter yea i did that once back then when i first had a da i learn from that but i'll look at it again...
    soo are ALL your ground on?
    Trans, Thermo housing, VC (actual STUd)
    Chickens Eat Eggs
    south side hoe
    try swapping another main relay on!
    trans and thermo housing ground is on but the VC ground is missing...and i'll see if i can get a main relay...
    IA OPINIONATOR ilbcnu123's Avatar
    you might wanna get that VC ground on
    yea im gana look for my old set of ground kit and install a few grounds and i see what happens....thanks guys
    Chickens Eat Eggs
    south side hoe
    fixed it yet?
    barrow county
    i get out of school at 1:45 so if you want to stay later or on a weekend i can stop by and take a look. im in winder too
    hey man gimmme a call or text me 678 313 4584 corey
    i could help you figure this out tomorrow morning.
    check ur basics, spark, then fuel. im pretty sure ur not getting spark
    i live an exit down from ya
    Stone Mountain
    are you turning the key?
    jk. im with the above post. check for spark.
