Results 1 to 16 of 16
Thread: Need help..
    Certified Gearhead Nguyen128's Avatar
    Question Need help..
    i had some light scratches on my trunk so i found some scratch removing stuff at the house, i do not remember the name. i whiped it on with a sponge and then cleaned it up with a cotton towel. now the bad part... the area i applied the stuff looks like a foggy white like i ruined the clear coat. can anyone help me try and get this stuff off? it looks terrible. thanks for the help.
    Quote Originally Posted by Nguyen128 View Post
    mm sounds like you might have to buff it. whatever you used should have directions tho
    damn, i want that penis
    it did, i followed the directions but i think i applied too much and didn't whip it all off or something. if only i could find the bottle.
    gasoline always works to take stuff off but it might be too strong n go through your clear coat. if you didnt wipe it all off try water to get it off and a rag. its really up to you how far u want to go. u could maybe use nail polish remover
    GL
    water & rag wont work... been trying that. the cars brand new so i dont wanna go extreme and kill the paint. what will be worse... acetone or gas as far as clear coat goes?
    Senior Member antiv6's Avatar
    g-nett
    rubbing alcohol might get it off
    Dec 2009
    Get a good microfiber cloth and buff it off.
    Are you sure the stuff you used was for paint...And clear coat?
    Also, in the future, don't apply with a sponge. Always good quality, clean, microfiber or terry cloth.
    banned mother fucker
    far away
    did you put rubbing compound on it? if so see if its a light ,medium,hard grit. most likely get a high power buffer and buff it out.
    i found the bottle finally it's made by Blue Magic and it's called Rub-Out. bottle claims to easily remove light scratches, haze, swirl marks, and is clear coat safe. it's like a white semi thick liquid. i'll try the rubbing alcohol in the morning when it's not so dark out. yeah i applied with the sponge and then rubbed off with a terry cloth.
    far away
    if that dont work try buffing it out, that should do it
    Oct 2008
    pics? i am just curious as to how bad this is because i was looking at that stuff at the store once
    i don't have pics, only thing i have that would take pictures is my phone and that won't really show.
    it should buff out. i would try that before anything else
    jhk
    IA Member SRK420a's Avatar
    Lithonia,Ga
    Like everybody else is saying all you need to do is buff it out
    buff it
    Peek-a-boo mofucka what now?!
    buff it
