Results 1 to 2 of 2
Thread: Swaping B18A1 into a 91 civic si
    Default Swaping B18A1 into a 91 civic si
    What is everything that I need to swap the motor over. I will be using a 90-91 motor and ecu since my car and the 90-91 integras were obd0. This is my first motor swap ever so I wanna make sure this goes smooth as butter which it probably won't... I need everything to be hooked up correctly I will be getting my car BAR'd ( its a cali thing )
    1. B series motor mounts for my car http://cgi.ebay.com/ebaymotors/b16-b...#ht_500wt_1182
    2. Shift linkage(buying a innovative one off of ebay)
    3.90-93 integra axels and half shaft? I'll get the axels from autozone or kragens and the half shaft from the pick n pull
    Do I need the b series cable vss or will my sohc d series vss work? Will the engine harness from my d series plug right up to the plugs on my civic or will I need to modify some? I saw a rear tranny mount for a b series in a ef on CL do I need to buy that or will my stock one suffice?
    1.5T AnTi-PooN's Avatar
    L'villE
    harness will plug right up, get the ecu from the integra too, get your bseries mounts, shift linkage, and you need the bseries tranny, you need to save the throttle cable bracket off the d series
