Results 1 to 10 of 10
Thread: h22a4 honning?
    Warner robins ,Ga
    Exclamation h22a4 honning?
    does anyone know what stone the machine shop needs to use to do the h22a4 honning?
    IA's Biggest Grouch
    Kennesaw, GA
    Not sure, but if I remember correctly the H22 uses Honda's famous FRM sleeves which are harder than most of the honing stones.
    They use a different set of hones for them. I've asked them if there was a difference at where I get my machine work done.
    My line of work
    www.internationaljets.com
    GWINNETT IS GREAT!
    arent the h22's cylinder walls very weak?
    B-Town Crunk Force
    Statesboro, GA
    They are thin but actually pretty strong. By nature of their design though, they arent as easy to work with as the standard steel-lined cylinder.
    I dont know anything about the specifics of the honing stones though, just that they are graphite and usually three different grades of the stone are used.
    acworth, ga
    Quote Originally Posted by xdavidscenex View Post
    if the machine shop does not know what stone to use, then shop does no know anything about machining this motor. you can not hone it like a regular iron lined b series. your best bet is to get the whole block resleeve if you intend to build the motor up for speed.
    ultimate sleeper.
    North Augusta, SC
    PM AccordPride... He loves working on H22 and can do the honing also for a good price. I'd recommend him to anyone.
    Back to being stock and slow
    JHU-623, JHU-818
    or this, directly from helms
    Atl
    i wouldnt. the last 2 h motors i built required no honing. slap new rings and go. if there is deep damage find another block. or if your h motor is a open deck block get a machine shop to stamp steel sleeve replacements made by darton!!
    credibility and reputation
