Thread: z6 rods
    Senior Member cm7k24's Avatar
    kennesaw
    Default z6 rods
    im trying to purchase some z6 eagle rods from a buddy,
    but i have a y7 block, and some one brought up there is a possibility they are a different length, so my question is will those fit or are y7 rods shorter than the z6
    they will work just fine.
    My line of work
    www.internationaljets.com
    kennesaw
    awesome
    Oct 2008
    Quote Originally Posted by Starrfire View Post
    x2 ....they are identical down to the 1/100 mm
    They def will fit. and even if they were slightly longer but still fit it would just increase the stroke if im not mistaken
    Oct 2008
    D16anydamnthing (D16XX) has a rod/stroke ratio of 1.52 and all of the rods are 137mm. Honda's test limit is within 1/100mm; Therefore, if they are not exactly that size, then they become scrap metal. In the case that you find a new rod that does not fit those perimeters inside a production car, then you have the rights to sue, fire or rape somebody!!!
    Edited: I believe the y7 compression ratio is slightly higher than the z6...this is because of the pistons ONLY
