Results 1 to 13 of 13
Thread: probe gt boost leak
    ^^this guy loves you jdm-civic's Avatar
    the sky
    Default probe gt boost leak
    ok i had a question, first off im whipping a 92 ford probe gt with manual boost controller and turboxs blow off valve and thats all and somtimes while driving it will only boost to a max of like 8 psi when the mbc is set to 14. now its only occasionally and i checked all lines, hoses and connections and there arent any leaks that i can see, feel, or hear. is this a common on turbo cars or is there something going horribly wrong?
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    ALL CAPS JITB's Avatar
    Quote Originally Posted by jdm-civic View Post
    the probe gt wont boost past 8lbs, on the stock ecu. unless you get a standalone, or get the chipped ecu. Ther used to be a guy that sold them, but he doesnt anymore, google Zombie Chip Probe GT. It was the best thing for the probe turbos! Im sure someone has figured out a way or started to make a chip for it, but i havent been on the probe forums in years!
    the sky
    it has the probanator chip which removes the fuel cut at 12 psi and sometimes if i ease on the throttle it will run 14 psi all day but sometimes it just boosts to 10psi.i was wondering is there like a problem with the turbo or something
    does it break up? or stutter? it may just be running out of fuel.. But those hoses are so shitty in that car, over the years. they break just by looking at them.
    the sky
    no it does not stutter or anything but it just doesnt go past 10 some pulls.it feels like it not getting full boost like the bov is getting stuck open but it has a turboxs bov and those are supposed to be a pretty reputable company
    take the bov off, and put the stock one back on, and run it with the recirculating pipe back on if you have it. i gues it sounds like u do have a leak. but be careful looking for it, everything plastic will break!!
    General Tech Hater
    Whoa man! Factory F2T cars can see up to 16 lbs. before the factory ECU starts throwing boost cut at the car. MBCs are crap. Although it may not be the problem, but invest in an EBC. I think they make some kind of boost leak tester, try finding one of those.
    EDIT: QUIT BEING RETARDED, THE DIY SECTION IS NOT FOR YOUR RETARDED PROBLEMS, POST IN GENERAL TECH SMART GUY.
    the sky
    well see thats the problem i dont have any of the factory pieces anymore and pull a parts has like no probes for me to get the factory pieces
    well than dont touch anythin eles, bc they are fragile..lol But it does sound like you have a leak. You can try and get soem starter fluid, and spray around vaccum hoses, and turbo hoses. And see if the idle raises.. but it sounds like its a real small leak, so this method may not work. But It prob is from one of the additions the bov, and or the mbc.
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    Sound like the blow off valve is leaking
    92 mx3
    Go Skateboard. ItsBlack's Avatar
    Do you have an actual manual boost controller or a homeade bleeder valve type
    the sky
    no its a actual manual bov....i wouldnt trust myself with anything home made
    take it off, and see if it will hold boost, but of course dont floor it...lol its not the best method.. but it will let you know.
Tags for this Thread
