Thread: 5.0 Problems
    SHP Josh...'s Avatar
    Default 5.0 Problems
    Alright I have a 93 5.0 with a 97 Explorer bottom end, 255 Holley FI pump, 24# inj., Track Heat intake, 70mm tb, full exhaust, etc.
    Ok I just put a set of heads, an F cam, 1.6 rollers, new lifters, and push rods. and if I sit in traffic for a few minuets my idle will drop from 1000 and will surge back in forth from 900-750 and will run like shit. When I start off I have to give it a lot more gas and the car will buck back and forth if I don't stay in the gas. But before when the car maintains 1000 idle it runs great and doesn't buck. Also while the car is running great, if I stomp on the gas and let off then the car will start bucking as well. The car didn't do this before the heads etc where put on, any help would be much appreciated.
    --edit also the car is at operating temp.
    Quote Originally Posted by xtquickgt00 View Post
    my car is an automatic my overdrive button wasnt working during the dyno i fixed it afterwards. i live out towards cartersville and me and ted were messig around the hole way to powder springs so he converter was hot also... after i dynoed it i puyt it back to stock and it felt stronger and my wheels bent on the pass. side hell fr what it was ying on th dyno ican still manage to get a 14.00 in the 1/4
