Results 1 to 11 of 11
Thread: Loosing Too Much Gas...
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Default Loosing Too Much Gas...
    PROBLEM FIXED!! DELETE
    GWINNETT IS GREAT!
    wow..idk where to begin
    efs got hella vac lines. make sure yours are all right. any mods to effect your mileage.
    With Your Mom
    some one said might be gas pump?
    wherever
    How can you loose gas?
    02' Miata
    barrow county
    cant be gas pump, it just pump gas to the motor, if fuel pump is bad than your engine will only turn over not fire.
    check if theres any leak in your gas tank/fuel lines
    Oct 2008
    x2 check for fuel leaks.....if it is really that serious than it should smell funny or something will blow up....lol.....check under the car and inside the engine compatrment. if no leak, then i would check the screen/filter arm thing that the fuel pump attaches to. This is the mechanism that determines your fuel level. (Technically, this would mean that you are not loosing gas, but just measuring it wrong.) Overtime the filter will fill up with debris or corroded material from inside the tank causing it to weigh down or corrode itself and eventually be inoperable.......In general, this is a common issue in older cars
    Oct 2008
    Bankhead
    maybe your car needs a tune up
    With Your Mom
    Quote Originally Posted by djpikachu1 View Post
    ive done the whole tune up chance..from oil to spark plugs to cable.
    alot of maintance
    Oct 2008
    it was the fuel pump lever wasn't it?
    With Your Mom
    yes lol
