- Idling Problems
SPUNKY MONKEY
- Rep Power
- 21
Idling Problems
I have a 97 civic n i just swapped a z6 motor into it! I used a conversion harness the car cranks up n it bogs for like five seconds n then it turns off so i crank it up again an it stays on but idles bad....weeeeuuuuUUUUMMM....weeeeeuuuuUUUUUM and over and over and as the car heats up my temperature gauge is still cold but the idling slows down...it idles good but after like 10 seconds it starts accelerating again doing the weeeeeeeeeeeeeeeuuuuuuuuuuuuuuuuuuuuuUUUUUUUUMMMMM MM n does it slow again...any ideas what it could be....i cleaned up the idle air control valve but nothing....i remember we changed the throttle body cuz the other one had a sensor that when we unplugged it the car didnt turn off n it was suppose to so we changed it but the gasket on the throttle body was chipped off in a corner could that be causing the problem? N when i started driving it it runs good if i dont step on it bt if i step on it, it starts bogging out n not goin nowhere....Any help or information on things i might need to change would be appreciated! THANX I.A.
- Idling Problems
- You may not post replies
- You may not edit your posts
Forum Rules
